-   -   Brake fluid reservoir overflow (http://forums.pelicanparts.com/porsche-911-technical-forum/914001-brake-fluid-reservoir-overflow.html)
85911 05-12-2016 12:26 PM
I'm working on my brakes on my 85 Carrera and have traced the brake fluid reservoir overflow line to a point behind the fuse block where it goes down through a hole in the inner fender. Where does it end/drain?
http://forums.pelicanparts.com/uploa...1463080958.jpg
Also, in the front of the driver's side wheel well, there are 2 plastic containers. I have looked at every parts diagram in the catalog and I think one is the windshield washer fluid reservoir. What is the other one?
http://forums.pelicanparts.com/uploa...1463081020.jpg
Thanks.
JRSIII 05-12-2016 12:31 PM
Not sure where the overflow drains. The second plastic canister is the fuel vapor evaporation chamber.
JRSIII 05-12-2016 12:34 PM
I believe it serves as a "wide spot in the line" to allow vapors to be sucked back to the carbon canister that is located in the right rear wheel well and allow liquids to drain back to the fuel tank. It's part of emission control system.
Look at page 240-23 in Bentley.
KTL 05-12-2016 02:35 PM
The overflow drains in front of the windshield washer reservoir. The white plastic tube is held against the chassis tub with some metal tabs. Look under the front spoiler/valance where the front of the chassis tub and side of the chassis tub meet at the corner and you'll see it.
sugarwood 05-12-2016 04:43 PM
Originally Posted by sugarwood (Post 8157629)
http://i57.tinypic.com/5d3pg9.jpg
Oh, and I had 2 questions about something else in the driver's front wheel well.
What are the upper and lower tanks for?
That zip tie is creating a serious kink in the circled hose.
The kink does not show up clearly in this photo, but it's pretty big.
How concerned should I be?
Upper tank is catch tank for gas tank venting. Lower tank is windshield wiper fluid. Since that is fill line to ww tank I wouldn't be too concerned unless severely constricted.
85911 05-13-2016 08:29 AM
All: Thanks. Bentley 240-23 shows the tank in the schematic.
Appreciate all of your help.
