Problem with transmission parts need help
I bought the 3,4 and the 5th dog teeth part #90130224203 when I received is not the same one for mine a 915/61, se pictures attached is a modification or I got the wrong ones need helphttp://forums.pelicanparts.com/uploa...1463318473.jpg
http://forums.pelicanparts.com/uploa...1463318491.jpg http://forums.pelicanparts.com/uploa...1463318509.jpg |
Is it bigger? Did you get a 915 2gear set of teeth?
If it's the same diameter, it's the right part. 3/4/5 are all the same. What do you think is different?
the problem is right on the opening part one has like indent, next use one is flat on the opening and the new ones are different on the opennings
http://forums.pelicanparts.com/uploa...1463319165.jpg
this is the other one |
No problemo.
matt and john, also I got a problem with the bell housing mean by this is the part facing the engine the bearing for the shaft , the races are easily remove and I saw videos posted that the housing is no good
no problem means I can use
I'm sure there are other places that do this. |
| All times are GMT -8. The time now is 05:37 AM. |
