Burnin' Rubber
Battery cable gauge
I’m in the process of tidying up around my 84’s battery…
I’d like to change the original battery connector ends to o-ring connectors. What gauge is the massive wiring? If I cut off the ends, will it fray, be unruly and become very difficult to form in order to shove a new o-ring connector on? Silly questions, I apologize. What I need to know more than anything else is the gauge so I can get the right o-ring connector ends. |
Big black wire from battery + to starter is 35mm2 according to factory diagrams. That translates to 1.8 AWG.
Gilles RoW 88 Carrera coupé |
Burnin' Rubber
PCA Member since 1988
A 2AWG connector ring should fit. I don't have a crimping tool that big (few of us do), so when I crimp on large connectors, I also solder the joint to make sure it has good electrical conductivity.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Kroon sells an excellent ground wire kit. I actually replaced my stock one as it was getting a little old and stiff.
Great product with great quality, really settled my mind about that essential connection. D. |
I replaced a section of mine with product from batterycablesusa.com. Great products, reasonable cost, and fast delivery.
