-   -   78 distributor rotation direction (http://forums.pelicanparts.com/porsche-911-technical-forum/914434-78-distributor-rotation-direction.html)
inaminit 05-15-2016 04:53 PM
I have a 78 engine on a test stand and I want to run it on the stand prior to putting it in the car. This is my first sc engine. Right now I am diagnosing a no spark condition. So I was checking the distributor with the cap off and the rotor rotates counterclockwise, both with the starter and by hand with a wrench on the alternator nut. The Bentley clearly states that rotation is clockwise. There is an arrow on the distributor body that points ccw, and the sticker under the engine lid indicates ccw.
I did a search on this forum, and there is one thread back in 2002 that indicates ccw rotation in sc's is correct, but there are lots of other threads that indicate cw is the correct rotation, but not specifically for sc's. The dist number is 0 237 304 06/PGUF6
Anyone? Thanks in advance!
Mark Salvetti 05-15-2016 05:20 PM
That is pretty well known error in the Bentley. It should read CCW.
Bentley has an update on their website: https://wiki.bentleypublishers.com/pages/viewpage.action?pageId=12910636
Mark
timmy2 05-15-2016 05:21 PM
78-83 SC' are CCW.
911ducktail 05-15-2016 06:15 PM
has there ever been any explanation as to why this was done for the SC? more trivia than required knowledge I guess...
VFR750 05-16-2016 02:34 AM
It is an odd thing. Maybe someone screwd up the drawing and too many parts were ordered before they figured it out? I'd be interested in knowing too.
wi54545 05-16-2016 04:11 AM
This design change cost me an air box last week. The bright side of it is that I get to drop my engine again so I'll be a pro now.
inaminit 05-16-2016 01:10 PM
Thanks for the answers and the discussion. Hopefully, if this question occurs again, this thread will pop up during a search.
Jdub 05-16-2016 02:29 PM
These distributors also feature a pinion with a unique pitch to it if I recall correctly. It just means you always want to retain your OEM distributor with the early '78's and be sure the pinion matches its counterpart in the engine.
930cabman 10-05-2025 02:04 PM
CW or CCW
Could it be so simple as placing the wires in the opposite direction? Pinion gear will not interchange?
How why would the guys have done this?
gled49 10-06-2025 07:34 AM
Porsche has a history of changing things so updates and back dates are difficult to impossible. The CCW distributor is one example.
