Sparco seats in 87 930 - which brackets?
Hi!
I'm looking to install a Sparco EVO driver, and an EVO II passenger seat in my car. I do not plan on using sliders. The seat mounting rails on my tub are stock, and I would prefer to keep them that way if possible. Which Sparco side mounts have you guys used to install these seats? The standard ones or the straight versions? Thanks,
Garen GNdesignLLC.com - Automotive Art & Sculpture Last edited by Garen; 05-12-2016 at 02:40 PM.. |
Interested to know myself. There is also this cheaper option
Planted Steel Offset Universal Side Mount- Black
J Mac Current 0 Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified |
Fastest Hunk of Junk
Are you going to want sliders?
I'm in for answers as well, since I just hard-mounted an Evo to the stock rails of my '86 using the standard Sparco brackets--but I had to mount the outboard bracket "backwards" (otherwise the brackets were 2" too far apart) and I'm not really satisfied with that solution. It did net me the extra headroom I wanted. Edit: for clarification, I used bracket A with the inboard bracket mounted normally, and the outboard backwards. This limited how low I could get the seat and seems sturdy, but can't be ideal. Bonus: it did move the seat further inboard to better align with the pedals.
-Brent Last edited by Bleedsblue; 05-12-2016 at 02:44 PM.. |
Good point that I forgot to mention. No sliders. I will update the original post to reflect this as well.
Garen GNdesignLLC.com - Automotive Art & Sculpture |
I just did Evo III on sliders in my car. Had to cut down the shoulders and remold them to fit. Love them.
The tech at Sparco Irvine told me that since I was using Sparco sliders I should not use the aluminum brackets. Too much flex. No sliders and the aluminum are ok. |
Oops, I didn't use the A brackets, mine are steel (no flex whatsoever).
-Brent |
Mine are shaped like "B" but in steel.
Thanks. I'm trying to see if I will need to order A for one side and B for the other, given the difference in widths for the standard EVO and the EVO 2. I don't see any drawings for the mounts like they have for the seats on the Sparco site.
Anyone else run this setup? Thanks in advance!
C and A will not work with your seats (the evo 2 that is) you will need the "b" to make the setup as narrow as possible.
do you have a sunroof? when I installed my evo 2 seats I could not get them to sit low enough on my car to fit a helmet and still have head clearance. the issue is the seat is wider than your stock mounts so the seat can not sit low enough- I had to do a good amount of work to my car to make them fit- if you would like to talk over the phone shoot me a pm and we will connect here is what I had to do
Thanks. Much appreciated. I will PM you in a bit.
