911 carrera 3.2 (1985)
radio/battery
I recently rewired my radio and speaker cables. After the installation and testing the battery went flat (no short-circuit, but radio and interior light on all day).
I recharged the battery with a tickle-charger. After the battery was charged I tested the radio again and found out that when I was 'pumping up' the volume, the radio went down for one second and then restarted. I tried to start the engine and .... the battery was down again. Can anybody help me? PS I haven't driven the car after recharging the battery. |
Did you wire the radio to a switched power source, such as the Acc. position of your ignition switch? A single interior lamp will drain a battrery overnight if not fully charged ... and a trickle charger won't fully recharge a dead battery! They are intended only to 'maintain' a battery's condition. To fully charge a dead battery takes a charger in the 6-10 Amp range, minimum ... and, running a car battery all the way down reduces its' lifetime, as 'normal' batteries aren't designed for deep-cycle discharge!
------------------ Warren Hall 1973 911S Targa 1992 Dodge Dakota 5.2 4X4 parts hauler [This message has been edited by Early_S_Man (edited 10-12-2001).] |
sounds like a weak, old battery. charge it good (until the hydrometer reads in the 1250 area), and do a load test to see if holds a charge.
