-   -   What is it? Where does it go? (http://forums.pelicanparts.com/porsche-911-technical-forum/915032-what-where-does-go.html)
Missed Approach 05-19-2016 07:59 PM
She is a 1986 3.2 Coupe w/ factory alarm- I removed the door panel to clean & lube the passenger side door latch/lock/springs/etc. (Note: the original vapor barrier was still in place!) and this was laying in the bottom of the inner door. I have reviewed the '86 exploded parts schematic and I cannot find a match anywhere. It is appx. 1/2 inch in height, non-ferrous (non-magnetic) and heavy. I suspect it is lead. Where does it go?
http://forums.pelicanparts.com/uploa...1463712968.jpg
timmy2 05-19-2016 08:05 PM
Spring retainer pin on window winder assembly.
Do a search, fairly common to fall out and need replacement.
Pelican sells them.
Missed Approach 05-19-2016 08:18 PM
Thank you Dennis!!! Found all the data- ordering from our host!
