sal sal is offline
Sal
sal's Avatar
Red face Need Vacuum Pod Parts 1983sc
I am in the process of rebuilding my Vacuum Pod Bosch 1-237-122-763 for my 1983 911sc. Does anybody have donor pods for parts? Any nonworking pods would be greatly appreciated! This pod has the two vacuum lines advance and retard. Any donor is wanted.
Old 05-17-2016, 06:07 AM
sal sal is offline
Sal
sal's Avatar
Help
Anybody?
Old 05-18-2016, 02:25 PM
Reiver
Reiver's Avatar
Sal,
I don't have any donor parts. Hope someone can help you out.
If I ever get in your position I'll just get a programmable MSD ignition box and set my advance in that manner.
De Oppresso Liber
Strength and Honor 5th Legion
Old 05-18-2016, 03:03 PM
are you saying you want to open up the vacuum advance and fix it that way?
ive heard its possible but its not easy. what ive done is get a used mercedes 280 unit and with a small mod- use it on the 911. right now im running a bmw 525 unit that i found brand new and it works great. pm me and ill tell you where to find one NOS that will work for you, i think its a bmw unit
its difficult to find one that fits the 6 cyl distributor
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 05-18-2016, 07:18 PM
sal sal is offline
Sal
sal's Avatar
Vacuum Pod 911sc Project PICS
Here are some pics. I think I can salvage this pod with the right parts.
thanks
Old 05-18-2016, 08:21 PM
sal sal is offline
Sal
sal's Avatar
Vacuum Pod pics
Here are some more pics the rust ruined the spring in on the backside (retard). The diaphragms appear to be OK.
I even think that the guts of a Porsche 914 might work as long as it is an advance/retard type. My concern would be the rear spring that was rusted out would have the same tention.
sal
Old 05-18-2016, 08:40 PM
I'm trying to understand what this numbers on the shaft means. I tried to research it and I thought I read somewhere that the stamped number in the shaft means the calibration of the pod . Correct me if I'm wrong. Is the first number 2 means 2 lbs spring tension and the rest 763 is 7.63 cm length of shaft from diaphragm to end of shaft ?? I purchased a pod for the same year and they keep giving me a different part number which has a longer shaft. The new number is 2865 in the shaft if I recall. Is this means same tension but longer shaft ??? Thanks
Old 05-19-2016, 12:36 AM
sal sal is offline
Sal
sal's Avatar
Number on arm??
I will measure the arm and check this out. I so this info will come in very handy for finding the correct spring?
Old 05-21-2016, 05:40 AM
Tags
distributor , dizzy , retard , vacuum advance , vacuum pod
