Output flange bolts
Read every thread here and hoping for a little clarification. I can only find one flange bolt here on pelican and does not indicate as being a stretch bolt. The pet for an SC says it should be stretch.
Will this one work in any case regardless of whats installed now? I did see somewhere that the stretch bolt had been superceded. Hex Screw 10x75 90133227512 - Genuine Porsche | Pelican Parts Just trying to gather all the info so I only have to order once. |
Looks correct to me, the stretch bolts usually have a reduced shank between head and thread. I have not heard that its been superseded but as long as it is torqued correctly should be good. I reused that bolt when replacing the seal, cheapskate.
| All times are GMT -8. The time now is 11:01 PM. |
