-   -   Running rough after rebuild (http://forums.pelicanparts.com/porsche-911-technical-forum/915542-running-rough-after-rebuild.html)
911 Rod 06-13-2016 12:04 PM
Originally Posted by john walker's workshop (Post 9158349)
Normally, that pin is an allen head bolt. Yours looks like a set screw, not that it would make any difference if the height is the same.
All my manuals show the set screw as OEM.
DRACO A5OG 06-13-2016 12:17 PM
OP, he had a no start issue.
Take a look at the sensor side to make sure it did not get smacked.
JW, it looks like an allen set screw but the smack tweaked a top thread over???
911 Rod 06-29-2016 10:00 AM
Replaced both sensors and nothing has changed.
The damaged set screw worked fine in the car that the flywheel came from.
911 Rod 06-30-2016 12:58 PM
Any ideas gents?
911 Rod 07-08-2016 10:21 AM
Time to sell? lol
911 Rod 06-07-2017 02:01 PM
Update on solving the problem.
The new 3.4 was not happy with the chip I had in it.
Put in a chip designed for a 3.4 and it runs great. Set the base line idle and it doesn't stall anymore.
Hours of testing s##t and it was a five minute fix.
jlex 06-07-2017 02:16 PM
Yep, that's usually the way it goes :rolleyes:
