-   -   AC switch non-functioning... (http://forums.pelicanparts.com/porsche-911-technical-forum/915606-ac-switch-non-functioning.html)
86 911 Targa 05-25-2016 09:00 AM
Fuse panel connections.
http://forums.pelicanparts.com/uploa...1464191902.jpg
The black wire goes to pin # 86 of the
evaporator relay.
G.
andyt11 05-25-2016 09:03 AM
Originally Posted by 86 911 Targa (Post 9134539)
As I understand your issue, there is 12v on the evaporator relay pin #30
until you plug the relay into the socket. Right?
Let's start from there.
Gerry
Correct
andyt11 05-25-2016 09:05 AM
evaporator relay.
G.
thankyou . I'll check those too.
I love this forum.
GH85Carrera 05-25-2016 09:13 AM
Please take the time to make a final post with what the problem really was, and how you fixed it. It is always good to see a solution to a problem.
kuehl 05-25-2016 02:22 PM
Andy,
Assuming you have an 88 to 89 the wire colors at the primary AC relay in the smugglers box will be
Red to relay from AC fuse #2
Red/White from relay to AC evap blwr switch
Black to ign switch
Yellow to the starter circuit
So if you wanted to bypass the AC relay you'd jumper Red to Red/White
http://forums.pelicanparts.com/uploa...1464211246.jpg
andyt11 05-25-2016 06:39 PM
After all that, I aquired some new fuses today and low and behold after replacing fuse 2, everything works, blower, seats, perfect. Thank-you so much for all the clear trouble shooting. I wish i could have got the fuses yesterday, would have saved you all some time.
I've given myself another problem along the way though. I've broken one of the little springs in one of my electric seat switches. So I'm going to have to find an old switch to butcher.
Thanks again.
kuehl 05-25-2016 06:59 PM
Yawn
86 911 Targa 05-25-2016 07:27 PM
Thanks again.
Well done Andy-well done!!!!
I think I mentioned fuse #2 early in the game.
Best,
Gerry
http://forums.pelicanparts.com/uploa...1464229612.jpg
andyt11 05-25-2016 07:30 PM
You did. It was one of the simplest first things suggested.
Thanks again.
