-   -   Curious CIS Question (http://forums.pelicanparts.com/porsche-911-technical-forum/915669-curious-cis-question.html)
Steve F 05-25-2016 06:04 AM
Morning, I was just Curious as to why the FD and AFM have springs under the screws retaining them to the air box? Also is there a torque spec for those?
Thanks,Steve
strictly 05-25-2016 07:26 AM
i dont know th torque, but the only thing i can think off, is screws could work like a lock washer, by placing tension on both sides. If that the purpose, the question is why not lock washers.
gazzerr 05-25-2016 11:19 AM
The FD you "lightly" tighten then back off one full turn per the workshop manual. I took "lightly" to mean tighten up until you start to feel a decent amount of resistance from the spring then back it off a turn. The springs are there to isolate the FD because vibration and can throw off the metering in the FD apparently.
The screws there is a torque value. I'm a long way from my docs. Hopefully one of the guys has the CIS manual handy.
Steve F 05-25-2016 11:56 AM
Thank you very ......again:) That makes total sense, I didn't see that in my Bentley manual, will have to review it again:) At first looking at the CIS in the car, it looked so overwhelming, but now, having it all apart, it's starting to make more sense.
Cheers,Steve
gazzerr 05-25-2016 02:52 PM
Sure no probs. Good luck. If you PM me I can send you the PDF for the Porsche CIS workshop guide.
Sorry I misread your post. When you asked about the torque value I thought you were referring to the screws that hold the FD to the metering unit. There is a torque spec for those.
The allen bolts with springs that hold the whole unit to the airbox you just nip them up until you get a nice resistance - you don't tighten the heck out of them - and back them off a turn and you are done.
Steve F 05-26-2016 05:14 AM
you have a pm :)
