-   -   Driver's Door Lock & Window Switch Questions 911 SC (http://forums.pelicanparts.com/porsche-911-technical-forum/915854-drivers-door-lock-window-switch-questions-911-sc.html)
rs6er 05-26-2016 04:39 PM
Recently, my driver side door lock was spinning freely when I turned the key. I removed the door handle and discovered that the screw that holds the lock in was loose, so I tightened it, reinstalled the handle, and closed up the interior door panel.
When I tried to lock the car, the key wouldn't turn, so I took the interior panel off and took the picture below. Is the rabbit ear actuator (for want of a better term) in the correct position vis a vis the bar coming off the lock. What am I doing wrong?
Also, does anyone have a good picture of the wire connections for the passenger door switch that is in the driver's door? I seem to not have that right either.
http://forums.pelicanparts.com/uploa...1464305896.jpg
rs6er 05-26-2016 04:53 PM
Actually, I just tried the door lock, and it's working properly.
So I only need an answer to the question about the window switch wiring.
