center fill question
Hello all,
Installing a TRE center fill on my 67S outlaw - my question is how large of a hole should I drill in the hood? 5" minimum and 6" max - the 6" size aligns with the fiberglass under hood flange piece, however I have also seen them smaller - just large enough for the cap with a minimual gap. Advise? How have some of you done this? Yes - I did look at the other threads - I need to specifically address those using the TRE piece thanks |
It just so happens I just did one with Dave's parts today, the diameter of the hole you want is the same as the smaller circumference on the fiberglass flange. It looks better and will better match the remainder of the body gaps. Here take a look at my fb page, its all there
https://www.facebook.com/pages/ROCS-Auto-Inc/291225550912443 Note that this isn't all welded in yet but you can see what the process is. Regards Rich Goncalves, ROCS http://forums.pelicanparts.com/uploa...1465513634.jpg http://forums.pelicanparts.com/uploa...1465513676.jpg |
| All times are GMT -8. The time now is 10:38 AM. |
