-   -   Need some quick help! Brake caliper ? (http://forums.pelicanparts.com/porsche-911-technical-forum/916217-need-some-quick-help-brake-caliper.html)
Sicklyscott 05-30-2016 07:44 AM
I went to change my pads for an event coming up next week and ended up destroying a caliper trying to get the one pin out. A couple questions:
1. Where can I get a caliper new QUICKLY? I leave for the track Thursday afternoon. My last order with pelican took 2 weeks.
2. What is the proper way of removing the pins? Should they really be that difficult? One popped out easily, the other not so much (obvioisly).
faverymi 05-30-2016 07:47 AM
Post your location you may get a local pelican with some spare parts.
I twist the pin to loosen it and then gentle tap with a point and hammer.
Sicklyscott 05-30-2016 07:52 AM
Good point. I'm in Metuchen NJ, 08840.
I think the retainer clip broke preventing the pin from sliding out. After hitting it the casting that hold the pin broke.
So frustrated!!!
hangar21 05-30-2016 07:58 AM
Scott,
What year? I have a caliper that only good for parts from my 87 (3.2). See pixhttp://forums.pelicanparts.com/uploa...1464620298.jpg
Don't know if it will help?
Terry
universeman 05-30-2016 08:16 AM
I just pulled my calipers off my 82 SC and would be happy to ship you one or two instead of sending them back to PMB for my core charge. They work just fine, I just want to help out if possible. PM me for detail.
Sicklyscott 05-30-2016 09:57 AM
Sent you a PM Jason.
Drisump 05-30-2016 10:42 AM
I can't say I've had any problem driving the pins out, the retainer is not very robust. Probably a lot of corrosion between the bore and the pin. A bit of WD and some tapping to vibrate it into the bore would likely free up the next stubborn one. Hope everything turns out for your event. Cheers
sugarwood 05-30-2016 02:41 PM
I used a drift punch and a heavy hammer.
The pin tapped right out.
http://public.snapon.com/R_RRD/Objec...es/PPC905A.jpg
Kidasters 05-30-2016 03:13 PM
This -
except I use a dead-blow hammer.
It's a plastic clip holding the pin in the hole. Are you hitting the correct side (the back)? They should pop in and out very easily. If they don't, something is wrong.
Front or rear? I'm guessing rear. What year car?
The only help you'll get quick is from a local. Might try Rennlist as well.
If you want a new one, and have time, PMB are the guys:
PMB - Brake Page
Sicklyscott 05-30-2016 03:38 PM
The other 3 went well. What I said above about the pseudo cotter pin breaking off is what happened. I kept "tapping" with the drift but it looks like it slipped under the pin and put pressure on the casting which split. I'll post a pic later.
I need to find a caliper ASAP!
Bob Kontak 05-30-2016 03:44 PM
Jason is your best friend right now. My fronts are in a box. I can send mine as well.
PM - I will be at the shop for a couple of more hours.
