-   -   Way to manually lower the Windows? (http://forums.pelicanparts.com/porsche-911-technical-forum/916765-way-manually-lower-windows.html)
sempaipaul 06-03-2016 12:44 PM
Guys,
I have fully disassembled my car for paint and, forgot to power the Windows in the doors. Is there a manual crank? Or some way to do it without it being hooked all up to the car?
Thanks,
Paul
sempaipaul 06-03-2016 09:33 PM
Anyone?
RNajarian 06-03-2016 10:29 PM
I asked the same question 5 years ago, here is the thread. Hope it helps
http://forums.pelicanparts.com/porsche-911-technical-forum/613095-lowering-power-windor-removed-door.html
wayne robson 06-03-2016 11:32 PM
window switch
This may also help , but not sure if SC is the same
as my 84,i had mine out a year ago and for memory
remove the 2 blue,hold together then touch one of the red
on to them,---3 photos are for drivers side,and other 2 photos
are passenger side----may help,----but keep a couple of spare fuses, hope i am correct
for memory.
next to you.http://forums.pelicanparts.com/uploa...1465021314.jpg
http://forums.pelicanparts.com/uploa...1465021400.jpg
http://forums.pelicanparts.com/uploa...1465021466.jpg
wayne robson 06-03-2016 11:37 PM
missed passenger photos
ok.http://forums.pelicanparts.com/uploa...1465022163.jpg
http://forums.pelicanparts.com/uploa...1465022217.jpg
john walker's workshop 06-04-2016 07:11 AM
the two middle wires on the switch go to the motor. Attach jumper wires to them and touch the wires to battery + or -. If it goes the wrong way, swap the wires.
