Aftermarket Tach Install
Hi all,
I wanted to share a project I completed over the weekend. I have been having issues with a swinging tach on my 911 for a while now...I contemplated having it rebuild by NHS but opted to go a different route. I purchased a GR4.5-TACH-02-DM from SpeedHut and proceeded to wait a few weeks for the tach to come in.
First impressions, the tach is fantastic looking, matches the original gauges quite well, and they even had the option (not listed on their order form) to add high beam and turn signal indicators on the gauge.
The gauge is slightly smaller than the VDO it replaced but you cannot notice a discernible difference in the overall diameter once installed.
First, I needed a way to mount the tach into the existing hole in the dash, and wanted to use the same mounting as the OE VDO. Drew up a quick adapter ring in SolidWorks and then RP'd the piece.
Once that was done, there are small nubs on the "spin ring" that needed to be filled flush with the adapter ring in order for the original rubber grommet to slide over and seat properly.
Final installation:
Sorry for the poorly lit pictures, I will take more once the sun is in the correct position.
The gauge also features programmable shift lights and can be used with stock distributor ignition or a signal from an ECU (AEM Infinity in my case). I do not have anything with it operating as I am still in the process of wiring my engine and ECU package. I will also post more pictures of the actual assembly a bit later today.
Just thought I would share, I'm really pleased with the results.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 06-06-2016, 07:00 AM
Chain fence eating turbo
Very clean.
Old 06-06-2016, 07:30 AM
Here is how the assembly goes together:
-Jayson
IG: Signature_911
Old 06-06-2016, 10:53 AM
Elombard's Avatar
That is rediculously cool!
I cant believe they can do the TS lights? First thing I thought of when I read your post title.
Ball park price? I would love to have a shift light.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-06-2016, 11:10 AM
Erik,
I paid $220 out the door for the tach, and the adapter cost me material since I have access to a printer here at work. I can't wait to get this thing hooked up and tested!
And the TS and HB indicators are +12v controlled (they can do either +12v or Ground controlled) so hooking those up is as simple as splicing the +12v into the light to the respective wires.
-Jayson
IG: Signature_911
Old 06-06-2016, 11:25 AM
Elombard's Avatar
Nice, thats much more cost effective than I thought it would be. I wonder how I could get an adapter ring with out spending a fortune? I think there are places on the web that will print stuff when you send the file. Have to look into that.
Old 06-06-2016, 11:37 AM
I can send you the file for the adapter ring, there are a lot of places online that will print for you.
-Jayson
IG: Signature_911
Old 06-06-2016, 11:40 AM
Wer bremst verliert
JohnJL's Avatar
A+ for creativity and thanks for sharing.
The different fonts from the other gauges would bug me tho.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-06-2016, 12:58 PM
Very creative.
Old 06-06-2016, 01:07 PM
John,
You can supply them with a custom font, they will print in any font you desire. I was not aware of this until after I had placed my order. If you know the font of the VDO numerals, they will print them in that font.
-Jayson
IG: Signature_911
Old 06-06-2016, 01:46 PM
Great solution. For anyone considering 3D printing, a couple good resources are Fusion 360 for design and then upload to makexyz.com for pricing and finding printer. I have used them successfully.
Old 06-06-2016, 02:21 PM
Jayson I've PM'd you
Old 06-25-2018, 04:43 AM
scumbag
this is brilliant.
well done.
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
IG: @doktor_b
Old 06-25-2018, 07:08 AM
Sent you an email with the STL file for printing!
Originally Posted by chrisbalich View Post
this is brilliant.
well done.
Thank you sir! I have since moved on from the SpeedHut tacho and made an adapter for the AEM CD-5 programmable dash utilizing the factory rubber mounting grommet.
-Jayson
IG: Signature_911
Old 06-25-2018, 09:06 AM
scumbag
did the SpeedHut unit disappoint? or just cramming more info into less space?
TIA
IG: @doktor_b
Old 06-25-2018, 09:42 AM
TIA
The SpeedHut was fantastic, I'm not taking anything away from the quality and usability of the gauge. I opted, as you said, to cram more info into less space.
-Jayson
IG: Signature_911
Old 06-25-2018, 09:50 AM
Looking forward to seeing any details of the CD-5 install and operation!
77 911s
16 981gts
Old 06-25-2018, 11:32 AM
Here are a couple photos of it installed, with the first page on the screen in one of the images. I tried to mimic the OE VDO tach as much as possible, I have additional needle gauges for oil temp, oil pressure, and boost pressure, mimicked the oil pressure warning lamp, generator lamp, gear indicator, and numerical read outs for vehicle speed and lambda. The second page has vastly more info on it that are pertinent to tuning and a good overall image of engine conditions. There are alarms that will appear as text, along with some colored background bars on the second page that will illuminate the channel in red if an alarm condition is triggered. I will get more photos of the other screens when I have some time:
-Jayson
IG: Signature_911
Old 06-25-2018, 12:23 PM
Looks nice and really useful for EFI, should be getting my 506 soon.
77 911s
16 981gts
Old 06-25-2018, 03:11 PM
Super useful and 100% reversible.
-Jayson
IG: Signature_911
Old 06-25-2018, 03:15 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
