rnln's Avatar
Anyone used the "manual tire changer" from harborfrieght?
I wonder if anyone use this tool to change and balance car's tires?
Manual Tire Changer
Fat butt 911, 1987
Old 06-12-2016, 02:42 AM
rnln's Avatar
Sounds like it doesn't work on nice wheels
https://www.youtube.com/watch?v=9B2wZMvxSwY
Fat butt 911, 1987
Old 06-12-2016, 03:04 AM
Home of the Whopper
I have one. Its pretty useless on car tires. Works OK removing tires from the dune buggies, 4 wheelers and dirt bikes. Only use I have found for the car tires is removing the strip of tire left after using a sawzall.
1968 912 coupe
1971 911E Targa rustbucket
1972 914 1.7
1987 924S
Old 06-12-2016, 05:51 AM
Elombard's Avatar
I have long wondered about this tool. Never thought to check you tube. I would love to be able to change tires at the house. but no one has invented a cost effective way to do it yet.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-12-2016, 07:19 AM
Platinum Member
dad911's Avatar
I've done it manually, in the 70's, when my fiat rims would not fit on the tire changer at work.
It's not easy to break the beads by hand. I used to lay my tire/wheel on the ground, with valve removed from valve stem, and break the bead by lowering another car's tire on mine with the lift.
Then used tire spoons to get the tire off.
That HF tool looks too light duty.
Old 06-12-2016, 07:28 AM
6 cylinder symphony
I got one to change the tire on my daughter's go-kart. It sucked at that.
I agree - I wish I had a real tire machine.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 06-12-2016, 10:17 AM
