RallyJon's Avatar
Unhappy 930S wheel fitment problems
Due to travel schedules, Christmas came early this year and I was happy to find a 930S steering wheel under the tree this morning.
After a quick trip to Sears for a 27mm socket, I tried to install it. Unfortunately it doesn't quite fit. Here is a side-by-side photo with the current hub (930S on the left). It looks like the current one goes deeper down the steering column than the 930S version.
The result of this is that the column doesn't stick through the hub enough to get the 27mm nut on. Here's a view from inside with the new hub pushed all the way in:
Are there different versions of the hub available? My wife said she specifed that is was a 1971, but maybe I have a steering column from a later car (lots of parts have been updated). Do I have to remove parts from the old hub and use them instead? I read the various install threads here, but nobody mentioned this problem.
Thanks for any advice,
- Jon
993 · 911 · STI · S4 · rally car
Old 12-22-2002, 01:32 PM
the long hub is for a later car. 74 and up. i never tried a 930 wheel on a 73 and earlier. hope there's an adapter for it. horn contact is different too.
206 637 4071
Old 12-22-2002, 01:44 PM
Author of "101 Projects"
Wayne 962's Avatar
Jon, did she buy it from us? We only have the 1974-89 adapter available at this time (the early adapters have been held up due to a snafu with Germany - I expect to get them next week or the week after).
In our catalog, we only list the wheel for 1974-89 right now.
I would be happy to swap out the adapter for the correct one when they do come in, if you did indeed buy it from us. (I don't have your order info to check)...
-Wayne
Old 12-22-2002, 01:49 PM
RallyJon's Avatar
Smile
Thanks!
Wayne, I PM'ed you the order number.
Old 12-22-2002, 02:51 PM
