Heat Exchangers?
Hey Guys! this may be a newbie question, but I have a 1976 911S Targa with a 2.7. If I was to take the stock heat exchangers out and replace them with Just headers, will I lose my cabin heat? if so.. Is there a way to still have heat?
Old 06-21-2016, 10:49 AM
yes, the heat exchangers are the source of cabin heat -- have you looked into SSIs? These are stainless copies of the headers the 911 engines used before emission regulations necessitated the single-out headers used by your '76 (and later 911s)- these do have heat exchangers, provide a near-ideal exhaust setup and should provide objective changes to your 911
Old 06-21-2016, 11:00 AM
Under the radar
Trackrash's Avatar
+1 on SSIs or just stock 69-73 heat exchangers and muffler.
Only problem might be smog certification, depending on your location.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-21-2016, 11:53 AM
Do the stainless SSI's alter the sound any? Or, increase HP a couple of points?
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 06-21-2016, 03:38 PM
yes and yes -- Unlike the 74+ heat exchangers, the SSIs don't merge the two cylinder banks together into a single outlet -- each cylinder bank exits into the muffler from its own outlet and requires a dual inlet muffler to work. These dual inlet mufflers generally provide a bit more "engaging" of a sound than their single inlet counterparts.
Further, since SSIs are freer flowing than the 74+ heat exchangers, they provide a minor boost (few HP) over the stock 74+ heat exchangers on 3.0 liter and smaller engines. On 3.2 and larger, they are a bit undersized and compromise top end power (but do provide a bit of a midrange bump)
Old 06-21-2016, 03:57 PM
Thanks for the great info. Guys!! I'll definitely be looking into the SSI's.
Old 06-21-2016, 07:36 PM
gearhead
Just a point of record 74 still used the early style HE's. One of many one year only transition features of 74.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-21-2016, 07:40 PM
