First ..I searched
![]() Thanks ![]()
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
I think on mine the fastener screw was on the right side (passenger) facing parallel to the front of the car. I don't think it really matters as long as it's not fouling anything? It's important you get a really good seal so it's airtight. There's a couple of nubs on the engine port that the hose goes over from memory. I put the fastener on under those.
Thank you Sir
Sure no probs. Another thing to watch for if you are replacing those breather hoses - there's one hose that has a restrictor in it at the oil tank end so look out for that so don't forget to install it in the new hose.
Does the restricter look like a hose splice nearer to the oil tank? Edit, just found it in the catalog
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS Last edited by Steve F; 06-16-2016 at 10:57 AM.. |
Hey Steve - no it's right in the end of one of the hoses that connects to the tank. It might be in the one that goes from the splice to the tank - kind of looks like a cone with the top chopped off on one end.
Got it! Thank you
