upwardr's Avatar
Gas flap spring
Any advice on installing the spring assembly. I must be attacking it wrong.
Larry
1971 911T
1983 Envemo, Cabriolet
1989 Carrera Cabriolet
Old 06-09-2016, 06:57 PM
schoward's Avatar
One of the most annoying 'jobs' you can do. Do a search - there is a trick and it goes something like this: Affix a zip tie or twist tie on the loop in the spring and fish the tie wrap through the slot in the pivoting thing (so you can hold the spring in position while you get the catch positioned and get the cotter pin in.
Once all is right - snip the tie wrap off and done. Even with this it took me 30 mins.
Scott
1981 911SC Targa - Platinum Metallic
Old 06-09-2016, 07:27 PM
J-Mac's Avatar
Well I never even gave that a thought. I'm sure my spring in my 75 is the original, or maybe not, it pops the lid with some attitude. But good to know there's a fix.
J Mac
Current 0
Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified
Old 06-09-2016, 09:39 PM
bdisco's Avatar
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
Fuel door lock - sticky cable fix
bad things happen when outta gas
Good luck
'88 Carrera
Old 06-10-2016, 05:48 AM
upwardr's Avatar
Well I did it, was a little rough but the secret with the zip tie was the only way to fly. Getting the cotter pin in without bending it was a bit of a bear.
Thanks all, small steps to get my car back together .
Larry
1971 911T
Old 06-13-2016, 07:47 PM
