-   -   3.6 conversion problems (http://forums.pelicanparts.com/porsche-911-technical-forum/91830-3-6-conversion-problems.html)
wm711 12-22-2002 06:26 PM
Hi everyone-
Fired up the 3.6 today...sort of. Engine hits, then quits immediately. This is reproducable time after time. You can keep the starter engaged and mess with the throttle, engine snorts, pops, acts like its out of time...any help is greatly appreciated-
Bill
Moses 12-22-2002 07:10 PM
On my 3.0 the same problem was a fuse to lambda sensor. Sounds like a fuel/timing/computer problem to me.
Kevin Stewart 12-22-2002 09:04 PM
did you do the up date on the distributor?, sounds like timming or a gas problem, which fuel pump did you use, Kevin
Joe Bob 12-22-2002 09:49 PM
Check it all.....fuel PRESSURE, timing and spark.....
