911Sc hard to start when hot
I recently replaced the fuel accumulator on my 911SC. The old one leaked fuel from the vacuum line. The new one also has a few drips of fuel at the vacuum line. Is this normal or do I have a defective in the new accumulator
Old 06-16-2016, 05:44 AM
Please post a picture.......
CaptainD,
I can't seem to visualize your problem by your description. The fuel accumulator is part of the fuel delivery system for your CIS and not related to any vacuum hoses. Where is the leak? A picture would be great. Have you checked your residual, control, and system fuel pressures? Or do you have ignition (spark) when the engine is warmed up? These are some of the critical things you need to test and check to get to the bottom of your problem/s. Keep us posted.
Tony
Old 06-16-2016, 06:00 AM
Tony,
The accumulator has a fuel line in and out on the top. at the bottom of the accumulator there is a vacuum line to the manifold of the engine. The old unit had fuel flowing out of the vacuum line, which indicated a leak in the diaphragm. The new unit leaks a few drops out of the vacuum line when disconnected. Is this normal
Old 06-16-2016, 06:30 AM
911SC accumulator: top: fuel in / out Bottom vacuum line
Old 06-16-2016, 06:56 AM
Tony,
Leaking from the line at the bottom of the accumulator is normal as you describe it--a few drops when the line is disconnected. The line is a return line to the tank, not the intake manifold, and as the fuel pump runs, that line is filled with fuel on it's way back to the tank therefore, there will be fuel in the line from the circulation of fuel, not from a leak in the diaphragm. The line should terminate in a T connector that connects the return lines from the WUR and the fuel distributor. The only way that line could leak a few drops of fuel when disconnected is if it was part of the fuel circulation, not if it was connected to the manifold.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 06-16-2016, 07:38 AM
OsoMoore's Avatar
A little leaked fuel when you switched the part is fine. If it is leaking fuel during normal operation, stop what you're doing and fix the leak now. We don't want another "car on fire" or worse post!
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 06-16-2016, 08:26 AM
Registered Minimalist
75 911s's Avatar
^ This and hot start issues are sometimes related to check valves after the fuel pump. Did you replace the fuel pump also?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 06-16-2016, 08:32 AM
