Vent Window Dismantling Tips
I need the glass from a vent window frame removed before it can be re-chromed. Any tips on how to do it? I can't seem to determine where to start. I do think I see a pin or something in the little moving handle. Should I try to remove that first?
Tap the pin out using a small punch. Then you can take the latch out. R/Dave
| All times are GMT -8. The time now is 08:07 PM. |
