-   -   O2 sensor wire extension - does it matter? (http://forums.pelicanparts.com/porsche-911-technical-forum/918601-o2-sensor-wire-extension-does-matter.html)
VFR750 06-17-2016 05:20 PM
I have one wideband O2 controller and sensor on the LHS. I added a bung to the RHS SSI headers. I want to check the RHS without adding a new controller, and I have a spare (old) O2 sensor.
I think I can just cut the old sensors wires and splice in 3-4 feet of wire so that I can install the O2 sensor on the RHS side, run the sensor wire over the engine and plug into the controller, without relocating the controller. Total distance is probably 6-7 feet.
Does the sensor wire length matter?
Can I splice in ordinary copper wire?
Anyone know if the innovate lc1 compensates?
James Brown 06-17-2016 07:40 PM
wideband sensor you will be OK adding another one, just remember to just crimp the connections and not soldier
