Is this a stock chip?
Hi all.
I just opened up the ECU to install a SW chip on my '88 Carrera and this was in there. SW's instructions note that the stock chip will have a number on the foil sticker whereas mine doesn't. TIA, Pip.
No, that's not a stock chip.
agreed - it's an Eprom from Signetics (S) with a window sticker from Texas Instruments (TI) (unusual).
There should be a nice long number on the sticker. Maybe Steve will read it for you and let you know if it is a copy of the original map or something else.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
This what a stock chip looks like
ok thanks for the responses guys. it also appears the soldered in "chip" above it is from TI too. strange!
![]() has anyone seen that chip changed/upgraded before and what may be the reason? |
S703 is an A/D converter.
I can't say if it was changed or stock because I don't know, but there is some interesting stuff here about the DME if you want to browse it: Inside a Carrera ML3.1 DME - Dorkiphus.net
from another Bosch ECU and installed in that one. And there aren't non-stock A/D chips being used, i.e. an A/D is an A/D.
Dave |
Interesting - I did not know that there was a Bosch number assigned and that chip mfrs went to the trouble of putting a client's own number on their ADC's - especially since an A/D is an A/D and that there were several (unknown to me) ADC mfrs' to select from. Good to know that the OP has an original.
1. a special temp range parameter screening 2. a certain data rate, etc. screening 3. to reduce reverse engineering ability 4. easier inventory control
Dave |
