Adjusting Valves
When Wayne's book say's to tighten the adjusting screw down on the feeler gauge how tight do we tighten. I'm putting a little oil on the feeler blade and then tightening down and then wiggling the blade out. How do I know if it's to tight. It's a 73 2.4
Mike
Old 06-26-2016, 07:28 AM
nene's Avatar
Mike,
I usually tighten then fairly good and have not had any problems. Use your judgment and your should be ok.
Old 06-26-2016, 07:54 AM
LakeCleElum's Avatar
Hundreds of valve adjust threads here........
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 06-26-2016, 08:00 AM
Fleabit peanut monkey
Bob Kontak's Avatar
No. Absolutely incorrect.
A slight drag only.
1981 911SC Targa
Old 06-26-2016, 08:07 AM
wolds's Avatar
Don't over think this process. Think about what you are trying to accomplish. If I set my valves to what I think is in spec and then I have my buddy go through them again we will arrive at the same acceptable result. This is why many mechanics use the "go, no go" process.
Old 06-26-2016, 08:21 AM
Originally Posted by bob kontak View Post
no. Absolutely incorrect.
A slight drag only.
this
Old 06-26-2016, 09:11 AM
And don't make the mistake of tightening the screw so tight to the point where you're actually pushing the valve stem in. Your feeler gauge should just touch the valve stem, not actually push it in. Personally, the best adjustment I've been able to give my car is with using the Kirk tool.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 06-26-2016, 09:59 AM
BER BER is offline
BER's Avatar
Porsche Crest
+2 Listen to Bob!
Think of pulling your feeler gauge across a small magnet.
Bruce
'12 Carrera S DFI
'84 911 Carrera
Old 06-26-2016, 10:48 AM
Thanks for all the replies I don't have the Kirk tool so Thanks Bob and others I like the slight drag and the small magnet discription.
Mike
Old 06-26-2016, 11:07 AM
