chickybok's Avatar
HELP 66 Early Fresh Air blower wiring
Can anyone help me wire in the following for a 66.
Early Fresh Air blower: Its the early type that sits in the smugglers compartment.
I have all the wiring / relay / and switch - But does anyone know how it all (the wiring that is) hooks up?
many thanks
David (aka Chickybok)
Old 09-23-2002, 09:34 AM
gregk1's Avatar
Well David I have a 66 911 and the blower setup that is in my smuglers box is a wabasto gas heater Is that what you have?? The 66 and 67's that I have there is no fresh air blowers they have wing windows for that
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 09-23-2002, 11:01 AM
chickybok's Avatar
I Know the vent windows do a good job, but...
Does anyone have an early fresh air blower fited? Its in Bret Johnson's guide - page 38/39.
Can anyone help?
Old 09-23-2002, 02:17 PM
chickybok's Avatar
Hi
Still trying to find out how a Fresh Air blower for an early 911/2 wires in.
Can any body help?
Many thanks
Old 12-25-2002, 05:38 AM
stormcrow's Avatar
David,
Generally the way it would be wired is as follows:
Relay
If the relay has four terminals two of the terminals would be used to energize the coil. The other two terminals would provide the 12V power to the blower.
Fan Switch
12V would come from the battery to one terminal on the relay coil. From the other terminal on the relay coil a wire would connect to it and the other end would connect to one terminal on the fan switch. A wire connected to the other side of the fan switch would go to ground.
Blower motor.
12V would come from the battery and connect to the normally open side of the relay terminal. Connect a wire to the other terminal on the normally open side of the relay and bring it to the blower motor terminal. From the other side of the blower motor terminal connect this to ground.
Operation
This is how it would operate.
When the switch was turned on, 12V power would go to the coil on the relay and energize it. The normally open terminal on the relay would close, allowing 12V to go to the blower motor and bring it on.
This is a simplfied method of wiring the fan if this is in fact the set up you have. I am not familiar with how many terminals your relay has, or if the fan switch has a low, medium or high speed.
But, if you wire it up like this, you can make it work.
"A Porsche does more then just go fast in a straight line"
Old 12-26-2002, 10:13 AM
