How to lower 911sc????
What is the best way to lower 911sc?
I assume adjust torsion bars?
What else do I need to do to ensure tyres don't rub on arches?
It's not a track car, it is purely for looks.
Old 06-26-2016, 07:28 AM
Under the radar
Trackrash's Avatar
The best way would be to take it to an expert on air cooled 911s and have it lowered, corner balanced and aligned.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-26-2016, 07:55 AM
If you don't have the tools and a lift its a PITA. You will spend hours and hours back and forth...up and down...and you most definitely will need an alignment when done. I did my SC with the help of a VERY knowledgable pelican and it took ALL DAY and part of another. It was worth it because the car looked fantastic properly set. Take the advice given above and find someone who can do it, corner balance it and align it. You may want to save money but trust me, if you don't know what you're doing you'll end up spending money anyway.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 06-26-2016, 08:37 AM
patz's Avatar
The front is easy. The rear not so.
I replaced the rear bushings AND the swing arms with adjustable ones. Doable DIY. But you will need an alignment.
If you have the coin, let a shop do it.
Old 06-26-2016, 08:48 AM
El Duderino
tirwin's Avatar
Lowering the rear is a bit of a pain. You have to re-index the torsion bars. It's not a super complicated process but it is a lot of labor.
The front is a different story. Easy (easier) to lower, but there are consequences. What happens is you affect the geometry of the control arms and the tie rods. This has been discussed a million times. You should read up before proceeding so you understand the implications. The short version is lowering increases bump steer. There are ways around this -- spacers or adjustable tie rod ends but proper solutions can get spendy. I did this and it involved raising the spindle height and adjustable tie rod ends plus rolling the fenders (I also have 21mm spacers up front).
If looks is the only reason you want to do this, then I advise you strongly rethink how much money you want to throw at looks.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 06-26-2016, 10:46 AM
Thanks for the advice which I will take on board
As the above have said needs set up after or it will handle like A dog.
Shocks and bushes already done
I know there is adjustment in the standard swing arms which should be ok for a 20mm drop. Unless anyone knows otherwise.
I'm running 17's
Old 06-26-2016, 10:47 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Scott Spence, the guy on the cover of Bruce Anderson's first edition Porsche 911 Handbook barked at me for suggesting this. I have told this story before.
He was adamant about torsion bar indexing only for street use when lowering. Said arm adjustments were for track adjustments, not routine daily drivers.
I only know what he said. I got nothing else except I did replace the bushings and index the bars. Then he aligned.
1981 911SC Targa
Old 06-26-2016, 11:57 AM
Under the radar
Trackrash's Avatar
I would like to hear the reasoning behind that statement.
Gordon
Old 06-26-2016, 12:20 PM
Bob Kontak's Avatar
I honestly do not know.
That is simply what the man said and I am certain of what he said.
I am not defending his statement but given his station, I am not disregarding what he said. I just don't know.
OP asked for input. That's all I had.
The street Porsche is not a race car. The obvious question is why did they make the arms adjustable then?
1981 911SC Targa
Old 06-26-2016, 01:13 PM
HarryD's Avatar
Some reading to help you figure the way forward: Lowering the Porsche 911 | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-26-2016, 01:21 PM
