check the ignition "run circuit" to coil
excellent old-school suggestion! - start first with the easy stuff:
- if the run circuit is damaged or disconnected or has developed a bad resistance you get exactly this symptom |
CIS troubleshooting..........
Ben, The system fuel pressure should be steady and should not fluctuate. Either the pressure gauge or the primary valve is defective or maybe both. This is something you could confirm. This is like taking a tire pressure reading. The pressure reading should be stable at X pressure. And should be reproducible. I don't see that from your test data. Your idle speed is also strange that it does not go over 1200 RPM during a cold start. You might as well test if the AAR (auxiliary air regulator) is open when cold and closed after 4 mins. This is easy to bench test. I am interested to see how the decel valve's vacuum hoses are connected particularly the one that goes to the WUR. Could you make a sketch how the decel valve, TV (thermotime valve), and WUR are connected? Thanks. Tony |
With regards to the primary valve, in my first post I replaced it along with the o-ring on the plunger. I pulled it out and both the valve and plunger looked ok. I can try the old plunger if you'd like. There was nothing wrong with it to my knowledge when I replaced it. Quote:
I figured it out!
It was the primary pressure regulator! The new one I bought to get the o-ring for the plunger is shorter than the one already in the FD. The difference is pretty clear when you put the large spring on (see attached photo).
Has anyone seen this before? The PPR I bought is 928 110 920 01. The US and UK PET's both say this part number. My FD is -031 for RoW http://forums.pelicanparts.com/uploa...1474589878.jpg The shorter length prevents the passages that allow the WUR return fuel to return to the tank from opening. When I put the plunger (silver bullet) on the PPR and push on it, I can see the longer PPR's passages open. On the shorter one it took significantly more force to open the passages. After reinstalling the old PPR, the pressures look to be good. I took a video of the pressure test: https://youtu.be/LSIM7FFvq7U . It looks like the residual pressure is failing with the old PPR installed, so I think the o-ring on the PPR is worn out. With the new PPR, the system maintained 1.1 bar for over 30mins after shutdown. Tony is going to send me a new o-ring I took a video of startup and idle: https://youtu.be/OTUD7JVCscA. I also drove it around and it seemed to run well! First time it has been running since May! Thank you for your support everyone! |
Primary pressure valve o-rings.........
Ben,
I am away from home and in Florida at the moment. There are two (2) o-rings for the PPR for FD-031. Will send the o-rings to you next week. Tony |
See post #42.........
Ben, In post #42, second sentence, it mentioned about the culprit. The troubleshooting became more difficult for you after you installed a different (wrong) PPV. Now that you have identified the problem and getting the right fuel pressures, time to tune the engine and enjoy driving the car. BTW, I will be sending you the o-rings after I get back home. Why don't you use the o-rings from the new PPR? And use the replacement o-rings in the 928 PPV? Send me a PM next week as a reminder. I will probably forget the o-rings after a day or two. Or I might remember it after several weeks. Thanks. Tony |
| All times are GMT -8. The time now is 06:24 AM. |
