How the Motronic EFI Works?
IIRC (us old guys use that caveat a lot), the Motronic EFI in the '84 to 89 911's:
1. Is a batch fire system rather than a sequential port injection system.
2.. Some batch fire systems fire every 720* of crank rotation but the Motronic fires every 360*.
If this is not the case can someone please explain or provide a reference that describes how the system works. Thanks
Old 07-08-2016, 05:54 AM
RETIRED
Joe Bob's Avatar
Talk to Ingo. 3.6@cox.net
2012 ML350 3.0 Turbo Diesel
Old 07-08-2016, 11:44 AM
drl911's Avatar
I can confirm those cars you reference are batch fire injection because when I changed to EFI recently with MS3Pro I was surprised to find the factory injector wiring harness ultimately ended up being one wire for all. I rewired it all for sequential injection supported by MS3Pro.
I am sure there are merits to squirting every 360° vs 720°, but in either case it is only supplying the fuel to the intake runner. The cylinder sucks in what's available when the intake valve opens.
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now....
'86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
Old 07-08-2016, 12:24 PM
Thanks, drl911
Old 07-08-2016, 12:38 PM
