Missed the point that you are removing the tempo motor and then jumpering those 2 pins in the engine bay. I get it now.
That should work just fine. Quote:
Will drill hole w/grommet for Rostra wiring input. Original body mount lowered if necessary, to fit.
http://forums.pelicanparts.com/uploa...1551894529.jpg http://forums.pelicanparts.com/uploa...1551894529.jpg |
Very good idea to gut an old control unit!
To bad you can't use the stock cruise stalk on the column :( |
P.S. I imagine if one was to insert a momentary micro switch in the end of the stalk you could use it. |
My '86 930 doesn't have CC. Is this Rostra Universal kit (250-1223) a good fit for my car? From reading this thread it sounds like those with the unit are satisfied with the results.
Interesting. Why not adapt a later g50/964/993 unit? They are plentiful used (I have a servo and ecu for sale) and seemingly last forever.
I can assure you, the factory system my 85 Carrera works great. It used to lose speed. I sent the control unit in to be rebuilt and that solved any issues. I just set it, and bam, it will stay at that speed for as long as traffic allows. On drives down I-40 from OKC, to where I-40 stops in Barstow, CA there are many long stretches where I could run for over an hour and not touch the pedals or the cruise control. Good luck with your 911. Now get out there and drive it! |
Surely one can do more beneficial DIYs on one's 911 than Mickey Mousing the wiring and adding
an after-market device for a minimum gain over an original Porsche feature, right? |
Here is why you are doomed: http://www.rostra.com/about-rostra.php |
Rostra sell stalks with both N/O or N/C switches - presumably to aid integration into existing harnesses etc. Seem to recall you set the control module dip switch to suit. So whichever way the factory switch works, should be possible to match it? Their docs say the control module can be permanently powered - e.g. via switched 12V on - so the on/off switch (with the LED) on their stalk seems pretty optional, as cruise disengages with either clutch or brake anyway.. At least, that's my plan :) |
Cruise unit is top right. The wiring for the system is pretty well self-contained. Sorry for the enormous size. Pelican doesn't seem to support image resize tags?
https://i.imgur.com/iEYHPf1.png |
Interesting. Thanks for sharing!
Sent from my iPad using Tapatalk |
As part of my build I had the OEM unit restored/rejuvenated by a well known outfit known to this board. Friggin engine raced to 7k before I had a chance to turn off the ignition. And this was in the garage. scary! Immediately tore the thing out.
I do allot of highway driving so I’m anxious to instal something “modern”. Now if Click or scuggy could harness the OEM stack for the Rostra, that would really by cool........ Just hoping..... Johan |
| All times are GMT -8. The time now is 09:18 PM. |
