Ronal R9's (16x8)/911SC
Just mounted up a set of Ronal R9's on my SC, shod with 225/45x16 Dunlop Direzza ZII Star Specs all the way around. Waiting on the /45's to grow on me compared to the normal /55 sidewalls I'm used to seeing, but they sure grip really well. Lowering just a bit more for autocross/HPDE tasking.
The studs don't seem to protrude as far out as compared to the factory Fuchs- has anyone else run a similar setup and seen this? Seems like a slightly longer stud or a steel lug might be best, but I may be overcooking this, too.
Any feedback appreciated, thanks.
Aaron Z.
1980 911SC 262K on the clock and peppy
1969 911T hot rod with AWD dreams
1979 FIAT Spider rusty, not trusty (yet)
Old 07-08-2016, 08:07 PM
Any slip on wheel spacers anywhere?
If not you won't have a problem, some wheels are just a bit thicker. Check to make sure the lug nut seats properly and are torqued to spec.
I've known people to run wheels and spacers with only 3 full turns of lug nut to fully seated. (Not optimal).
'82 911 SC
IG: @rywats
Old 07-08-2016, 09:47 PM
