-   -   915 Differential Output Seal DEPTH? (http://forums.pelicanparts.com/porsche-911-technical-forum/921132-915-differential-output-seal-depth.html)
DRACO A5OG 07-08-2016 11:09 PM
Hey Fellas,
So I replaced my seals, placed them flush but I noticed when I re-atached the D-side fange, the flange pressed the seal in about 3MM in and the flange is touching the seal.
http://img.photobucket.com/albums/v5...psssaumrjp.jpg
Now the P-side, there is a gap so the seal will not touching, WTD? :eek:
Question, should both seals be set in about 3MMs+ and should I push the D-side in further to keep it off the flange? I assume yes, but just want to verify.
TIA,
SmileWavy
DRACO A5OG 07-09-2016 09:34 AM
So it appears from the PAG diagram it should be flush.
Now I need to check why one flange is deeper than the other side, note mine is a LSD but that should not make a difference :D
http://img.photobucket.com/albums/v5...ps4j5mrf8s.jpg
Targa Me 07-09-2016 09:39 AM
Hello Jim,
It would be my guess that the seal should rest at the bottom of the cavity, or bore, that is accepting the seal. In other words, seat the seal at the bottom until it will no longer travel.
john walker's workshop 07-09-2016 09:47 AM
One side is flush and the side cover is deeper.
DRACO A5OG 07-09-2016 11:46 AM
Ah ha.
That is what the original seals were like
P-side was flush and D-side was set in, I will push D-side in a bit further to keep it off the flang
Thanks Dr JW
john walker's workshop 07-09-2016 04:05 PM
I use the flat side of the old seal and a plastic hammer to sink it in evenly. Watch your fingers.
DRACO A5OG 07-09-2016 04:47 PM
That is how I did it too, YES, ouch, smashed my fingers several times :eek:
So, I visited HD and found a SST for the install instead
The OD of the seal is 2.7 inches
This coupler's OD is also 2.7 :-)
http://img.photobucket.com/albums/v5...psw91kqzbd.jpg
Label is 2 X 3/4 PVC
http://img.photobucket.com/albums/v5...psc61jahz5.jpg
I will use a large washer and Diff bolt to "arbor" like press it in.
http://img.photobucket.com/albums/v5...pswe72bk4i.jpg
Too close for comfort so I will shave/sand the PVC down a tad so I can get D-side in the depth needed, if it won't fit on the diff easily
DRACO A5OG 07-09-2016 08:06 PM
Ah Poop,
Wouldn't you know it, the bolt is too short :eek: ok back to finger smashing time :-o, actually not, because of the height of the HD SST, plenty of room as not smash the fingers with the rubber mallet :D
Seals All Good :D
http://img.photobucket.com/albums/v5...pscnh1b9eh.jpg
P-Side
http://img.photobucket.com/albums/v5...psjhvo585s.jpg
D-Side
1MM Gap from seal surface both sides
MBEngineering 07-10-2016 01:07 AM
HI DRACO A5OG
what year is the gearbox, it looks like a SC/3.2 box,
which LSD have you fitted,
the diff seals are at 3 depths depending on the box/diff side plate,
the main case seal should be around 2mm below the case
the diff side plate (without the oil pump) is around 2mm for a SC and 8mm for a 3.2 (depending on which diff side plate is fitted) in from the outside of the case
the side with the oil pump is 12mm in from the outside of the case
it you have a box which started life with a open diff, do you know which/where the LSD came from, as the early diff will not sit in the middle of the diff case, causing one output shaft to sit close to the seal and the other to be well away from the seal, in a badly set up box and seal could cause the oil leak, due to the diff beeing fitted to deep in the case, the oil seal in to deep and the shaft is not sitting on the seal
the Porsche diff oil seal setting/fitting tools for 915 gearbox
http://forums.pelicanparts.com/uploa...1468137800.jpg
regards mike
DRACO A5OG 07-10-2016 08:05 AM
Brother Mike,
It was built by Peter Zimmerman and he stated he used oem LSD. Yes, I can concur, the P-Side (as one is seated in the car, right side) flange is definitely positioned outward further than the D-Side.
The diff plate for the D-side, I noticed is definitely has a recess/concaved then a lip to accommodate the seal vs the P-side lip which is flush with the diff case surface.
My main worry was the D-side flange rubbing against the seal, which is not a good thing at all.
So now I have matching gaps on both sides. Will keep an eye on them to insure no leakage, since i have the gear box out I could always take proper measurements :eek: using a straight edge.
