-   -   Identify this wire behind my dash? (http://forums.pelicanparts.com/porsche-911-technical-forum/921190-identify-wire-behind-my-dash.html)
Jameel 07-09-2016 02:38 PM
In the process of replacing my fresh air blower and rewiring my cigarette lighter socket I came across this loose wire. It's white w/ green stripe and has a piggyback terminal. It's coming from a group of two other wires that go to the rear defog switch. It's an '83 SC Coupe. I'm away from my Bentley manual, but will check it later tonight.
http://forums.pelicanparts.com/uploa...1468100204.jpg
NY65912 07-09-2016 02:44 PM
Don't know, but I'm interested as well. I have the same wire on my '85.
Joe Bob 07-09-2016 02:45 PM
Page 970-23 of the Bentley says it is an indicator lamp. So check your dash gauge idiot lights.
rwest 07-09-2016 03:46 PM
In that area, could be for the HVAC panel lights?
Jameel 07-09-2016 04:28 PM
That helps! But can you explain how you determined that from 970-23? I'm back at home now and am open to that page. There are two indicator lamps listed, oil pressure and generator. I don't think it's either one of those, I check those at every startup, and they were working just earlier today. More telling is that even if it were one of those, I don't think this wire is nearly long enough to reach over to the gauges. It's got to be something near the fog light/defog/seat belt light cluster.
Joe Bob 07-09-2016 04:35 PM
Your wire is in the trunk by the dash. I simply looked for a labeled green/white wire in the schematic.
timmy2 07-09-2016 05:50 PM
If it is with a black and a white/grey only, it is for the rear fog lamp in Europe.
Jameel 07-09-2016 08:00 PM
So I poked around a little more in here and here's what I found.
The terminal marked "III" on the back of the fog light switch has nothing going to it. And I couldn't find a reference to this in Bentley. So I just left it alone. The switch works fine, powers on the fogs, and the switch illuminates when on.
http://forums.pelicanparts.com/uploa...1468119297.jpg
Then I read timmy2's reply:
So I went back out and double checked the wire bundle. Yep, it was with a black and a white/grey only. Thanks timmy2. So now I'm wondering if the bare terminal on the fog switch is indeed for this wire, which perhaps the factory left disconnected for US cars since there's no rear fog here?
http://forums.pelicanparts.com/uploa...1468119620.jpg
E Sully 07-10-2016 09:58 AM
W/Grn is generally used for fog lights, or side marker(parking) light indicator on Speedometer.
