-   -   Part between the two rear tins (http://forums.pelicanparts.com/porsche-911-technical-forum/921230-part-between-two-rear-tins.html)
DRACO A5OG 07-09-2016 09:10 PM
Hella Fellas,
So, I was wondering what is the part or part number for the piece that goes between the two rear tins for a 3.2?
http://forums.pelicanparts.com/uploa...1139890413.jpg
The gap between tins 15 & 18 ( 911S but pictured for reference )
TIA :confused:
Jim
dad911 07-09-2016 10:13 PM
I think they connect together, no gap in between:
http://forums.pelicanparts.com/uploa...1291772953.jpg
DRACO A5OG 07-09-2016 10:34 PM
http://i60.photobucket.com/albums/h3...C/912c3fec.jpg
http://forums.pelicanparts.com/uploa...1181744839.jpg
I am talking about that middle piece, it appears to be a rubber piece/part.
steely 07-09-2016 10:51 PM
is it near the tdc sensor?
DRACO A5OG 07-09-2016 11:07 PM
If you look at the second picture, the red arrow goes across it for the oil Pressure Sensor.
Discseven 07-10-2016 06:03 AM
Brother Jim... looking at '79-930 tin set up. (Is not in final position due to engine mount.)
http://forums.pelicanparts.com/uploa...1468155567.jpg
http://forums.pelicanparts.com/uploa...1468155599.jpg
steely 07-10-2016 06:06 AM
Hmmmm, from what I can tell, that red arrow (pointing to the oil pressure sensor) in the second picture is going across the TDC sensor 911-606-108-00 (NLA).
Whether the TDC sensor is sitting in a separate carrier, or that whole thing is the TDCS I can't tell - from looking at images of the sensor itself. Or am I way off?
On edit,
the TDC sensor sits in a bracket 930 101 191 02
DRACO A5OG 07-10-2016 07:49 AM
Doh.
Ding Ding Ding, Winner Winner Chicken Dinner. STEELY hit it right on the head!
I just remembered I had Tony Calas at Calas Rennsport do a TDC sensor delete as it was no longer used. I did not realize that meant removal of the rubber block, Oh well, now I know.
I think I will make something up to block it up from a piece of rubber.
Thanks again Brothers!
steely 07-10-2016 10:16 AM
oh cool, how about that, I'd heard it was just as useful as an appendix. An NLA you won't have to worry about.
