Global circuit breaker for an SC...
100amps? 150 amps? Anyone with a racecar running one?
If you were putting a big circuit breaker after the battery to feed everything but the starter, what would you use? A breaker like this: ![]() Come to think of it, everything in the engine bay is fed off of the starter lug through a separate 50amp breaker, so take that out of the equation. So, basically the entire front fuse panel, what would be a safe breaker value? I have A/C with extra fans, things like an AFR gauge, USB ports, no stereo, no power seats, 90/100W headlights, all LED lighting elsewhere. I would think 100amps would be plenty, but maybe someone has experience.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
