Hilbilly Deluxe
Rebuild: I found where my oil went....
Well, the source of my oil consumption problem has been identified:
#2 Exhaust port, oil flowing down from the valve guide,into the port: They all look pretty much like this: ![]() #6 piston and head, exhaust port looks about the same, but this one had a broken oil control ring. The piece is sitting on the piston skirt. Interesting thing is the spark plug didn't look any different than the others. ![]() Other fun and games: Oil return tube art: 3 of 4 had the same little mountain buildup of oily dirt one one end. ![]() As I figured, my pistons are stamped KS ![]() Anyone have a set of used 3.2 Mahle jugs they need to unload for dirt cheap? Tom |
Acknowledging your problem is the first step to recovery.
As long as your getting new cylinders, might as well bump up the bore and compression.
Chuck Moreland - elephantracing.com - vonnen.com |
Author of "101 Projects"
See my warnings on increasing the compression on Motronic 3.2 engines:
Rebuilding 3.2L for power - suggestions please -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Senior Member
Tom, check your e-mail.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Hilbilly Deluxe
At this point, I am planning on JE pistons, and sending my cylinders up to Reno to get reconditioned. The reason I want a cheap set of jugs from a 3.2 is that the guys in Reno can bore them out to 98mm, with JE pistons for a fairly economical short stroke 3.2. Combined with 964 cams and SSI's it should be a nice little motor, work with my existing CIS system and still pass Smog. Quote:
For an engine that didn't drip any oil, it sure was filthy. ![]() Tom |
Nice pics Tom.
My SC's oil consumption is around 170 miles per quart. That's probably how mine looks on the inside. Rob 1980SC |
