LinkBack Thread Tools Rating: Thread Rating: 18 votes, 3.00 average.
Jonny, will your system work for the BEHR under dash blower unit and will it give more benefit.
Old 07-30-2019, 04:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #781 (permalink)
Jonny H's Avatar
You could plumb the under dash pipes to the Behr unit. It will be the same volume of air but there are more vents so the air speed will be reduced. It might allow you to position the air where you want it.
www.classicretrofit.com
Old 07-30-2019, 10:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #782 (permalink)
echecsqueen's Avatar
Does anyone on this thread know the following? I have a LHD '66 BUT insufficient room in my smuggler box (used it for a dual master cylinder conversion). Should I order the RHD model?
I have sent emails to Johnnys company via the website but no response.
Sent from my BBB100-1 using Tapatalk
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 08-01-2019, 07:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #783 (permalink)
Yes, the RHD version will allow you to mount the compressor in the front of your trunk instead of the smuggler’s box.
Regards,
David Yerkes
1987 911 Targa - GP White
Old 08-01-2019, 08:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #784 (permalink)
VFRPeter's Avatar
I believe that Jonnyís been away playing with a few more exotic Porsches, involving a twin spark 935, etc.
Iím due heíll respond soon but as per previous poster, yes the RHD kit will put the compressor in the front corner of the froot.
Peter
Old 08-01-2019, 12:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #785 (permalink)
Jonny H's Avatar
Hi Queenie. Busy time of year for us. Email me direct: info@classicretrofit.com.
Old 08-01-2019, 12:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #786 (permalink)
Thanks david and peter! Emailed johnny at the above. Will keep yall posted.
Q
Old 08-01-2019, 01:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #787 (permalink)
MikeD930's Avatar
Have anyone noticed high temps at the positive terminal on the battery after running the CR A/C? A couple weeks ago I went for a couple hr drive in mid 90's deg F temp so the A/C was working hard. After the drive I put the trickle charger on which I usually do since I don't drive during a work week I noticed the positive terminal being really hot. But I did not think about taking a temp reading at that time...so yesterday I decided to take a temp reading before and after 45 min drive around 90 deg F temp.
Before drive
After 45 min drive
I'm sure the battery terminal temp was over 120 deg F after 2 hr drive several weeks ago.
I'm wondering if it's a good idea to add a positive terminal away from the battery with wiring from both alternator and electric A/C attached to minimize heat transfer (caused by high current from alt to A/C) to the battery. Any thoughts?
MikeD
'87 930
Old 08-11-2019, 01:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #788 (permalink)
Resistance makes heat, first thing you should do is make sure terminal and connections are clean and tight.
Rutager West
Old 08-11-2019, 01:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #789 (permalink)
MikeD930's Avatar
Right...I agree but everything's clean and tight. So I'm wondering if anyone else noticed the terminal being warm/hot.
MikeD
'87 930
Old 08-11-2019, 01:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #790 (permalink)
Jonny042's Avatar
I wouldn't worry as long as the cable itself isn't hot - a large percentage of your increase in temp is from ambient temp (since you started out with a temp lower than ambeint). Plus then whatever else is going on in the compartment, including battery charge/discharge heat, compressor motor, etc.
87 Coupe - The Driver
78 Backdate - The Project http://forums.pelicanparts.com/porsche-911-technical-forum/979976-project-heavy-metal-all-steel-classic-remastered.html
85 Coupe - The Rot Rod! AX beater
Old 08-12-2019, 11:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #791 (permalink)
PNW_Boxer993's Avatar
As a 912E owner, I am very interested in this system! The question is whether the upgrade alternator can be used in the Type IV application. Can anyone comment on what challenges I may encounter? Everything else appears to be standard given 911S/912E likeness in all other aspects.
Has another 912E owner implemented the Classic Retrofit AC system?
Thanks, Tony
Old 08-28-2019, 05:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #792 (permalink)
Jonny H's Avatar
Thanks, Tony
We have a Type IV alternator in development then youíre good to go!
Old 08-28-2019, 12:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #793 (permalink)
914-6Werkshop
914 version soon? Please.
914-6Werkshop.com
Old 08-28-2019, 01:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #794 (permalink)
Most Excellent!! Thank you Jonny!
Mark - keen on the application in a 914 as well!
Old 08-29-2019, 05:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #795 (permalink)
Hbrand
hbrand's Avatar
Using the evaporator in the smuggles box ?
Anyone tried this ?
Electric compressor connected to the original Porsche evaporator inside the smuggles box.
This is what I want.
greetings, Harold
Cheers
1973 Porsche 911T RS
1967 Porsche 911 SWT
Lots of Austin Healey 100-4
Old 09-03-2019, 09:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #796 (permalink)
LJ851's Avatar
https://www.classicretrofit.com/collections/electric-air-conditioning/products/electrocooler-compressor-ecu-only
They sell just the compressor and the controller for it so that should do what you want, some assemble required.
Old 09-03-2019, 09:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #797 (permalink)
Jonny H's Avatar
You need the half kit. You retain the Porsche evaporator, everything else is in the kit.
https://www.classicretrofit.com/collections/electric-air-conditioning/products/air-conditioning-kit-for-classic-911-half-kit
Old 09-03-2019, 12:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #798 (permalink)
Morrie's Avatar
+1 on the 914 application Johnny. Glad to hear you are working on an alternator solution. That will probably sell stand alone also, as a supplement to your business.
68 912 Coupe, 76 914 2.0 backdated, 04 BMW 330Ci Cab, 08 Acura MDX "Porsche Support Vehicle"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S, 02 Ford Explorer - you served us well!
Old 09-03-2019, 01:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #799 (permalink)
Hbrand
hbrand's Avatar
Would also need then the Alternator and wire harness. Patrick Motors sells that ?
Originally Posted by hbrand View Post
Anyone tried this ?
greetings, Harold
Cheers
Old 09-03-2019, 01:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #800 (permalink)
