-   -   Classic Retrofit: Lightweight Electric Air Conditioning (http://forums.pelicanparts.com/porsche-911-technical-forum/921754-classic-retrofit-lightweight-electric-air-conditioning.html)
Jonny H 07-14-2016 01:29 PM
Keeping cool everyone?
<iframe width="420" height="315" src="https://www.youtube.com/embed/mc9oj_EwioY" frameborder="0" allowfullscreen></iframe>
MBAtarga 07-14-2016 01:59 PM
Sorry - I gave up after 2 mins - I can't understand what is being said - all I hear is background noise.
tobluforu 07-14-2016 02:13 PM
Wait, what? Degree's, Celsius, ambient, vent temps, me confused. No need for ac if its 56 degrees. or am I missing something?
jdbunda 07-14-2016 02:17 PM
Same here, the audio is really irritating. I am very interested in the product though! Could post some details?
aschen 07-14-2016 02:37 PM
Its an electric driven AC compressor, 40A@12v, so 1/2 HP or so.
I think its a good product for 911s, but I would worry about putting alot of stress on the charging system and the power sounds a bit on the lowside.
Jonny H 07-14-2016 02:37 PM
All temperatures are Celcius.
56 degrees Celsius is 132 Fahrenheit
30 degrees Celcius is 86 Fahrenheit
Sorry about the audio, 911s are noisy! Left hand gauge is vent temp, right hand is cabin temp.
eastbay 07-14-2016 02:56 PM
Definately want to see more info, looks super cool!
Fully contained in the frunk? If so, that is the way is should be with nice short lines between the condensor and evaporator.
tdw28210 07-14-2016 03:05 PM
A somewhat refined electric AC system for the 911 is something many would be interested in. That is assuming the price is competitive. Would like to know more. In the meantime, I'll visit the website.
UPDATE :nothing on the website about this product. We await your reply OP.
Jonny H 07-14-2016 03:25 PM
The system is fully contained in the luggage bay and weighs under 30 lbs. That weight is now in the right place too, at the front.
The cooling output is almost double that of the factory 964 a/c at idle. Our smart controller regulates output to avoid draining the battery.
We are doing hot climate testing through the summer, this is just a sneak preview. Full details will be available soon on our website.
tdw28210 07-14-2016 03:36 PM
OK, sign me up as your first stateside beta tester. I've purposely left out any traditional engine - based cooling system for my 3.2, lightweight '73 RSR tribute build in anticipation of an electric system. I am in Charlotte,NC so easy flights from Heathrow. :). And Haas F1 is just 45 minutes north. ����
lvporschepilot 07-14-2016 03:51 PM
very neat. looking forward to seeing further details
jpnovak 07-14-2016 04:08 PM
You want hot climate testing? Send me a unit here in TX. We have triple digit heat plus the humidity. Interesting concept. There has been quite a bit of speculation on electric AC systems in past threads. I think 40A is a bit too much current draw. Especially on the early alternators. Is that full current, duty cycle averaged, startup or other?
Jack Stands 07-14-2016 04:16 PM
Jeg's sells the compressor (~$1200), but it does draw a fair amount of current at 12 volts. If it could be made to work, a simple system that doesn't have so much hose length and additional ''stuff' in the engine compartment. I think one of the aftermarket AC vendors (Retroaire?) was evaluating this compressor as well, but I haven't heard any info as to their findings. A bit too expensive to just give it a try in case it doesn't work as advertised.
rick-l 07-14-2016 04:24 PM
Did something just explode over on Ban Island?
Jonny H 07-14-2016 04:29 PM
Our test mule SC has a 75A alternator. If you switch the headlights and rear screen demist on, that's 40A. Switch your wipers and stereo amp on, that's 55A. The alternator is able to handle that no problem.
Our controller has some monitoring smarts which are used to manage power, regulating the compressor if demand elsewhere is high. Yes, it is a compromise but so are a lot of things in a sports car.
Early cars are an issue. We are having high output alternators made for them.
We might have a car going to Dubai but not certain yet.
kevin930t 07-14-2016 04:32 PM
Sounds cool,no punt intended
Sent from my SM-N910T using Tapatalk
dos531 07-14-2016 05:12 PM
This seems like a great idea. What is the price point going to be?
Bob Ashlock 07-14-2016 05:15 PM
Maybe I missed it, but was there a view of the actual compressor / location? In general, I like the idea.... !
rwest 07-14-2016 05:22 PM
Electric cars have electric AC, so not too far of a stretch to see the systems being perfected enough to work well. Anxious to hear more details.
Elombard 07-14-2016 06:34 PM
I dont think electric cars are 12 volt though?
I am interested too. Hope you post more detail on the thread when its ready.
It would be really cool if a couple of simple wire hooks ups and quick release points and the bulk of it (say 25 of the 30 lbs) could be removed for track day!
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
