kdubb's Avatar
Question Torsion bar upgrade?
Is it ok to upgrade the front now and the rear later? Or, do they have to be done at the same time? Pro's / Cons?
Thank you
Old 07-15-2016, 06:49 AM
gtc gtc is offline
abides.
gtc's Avatar
It will throw off the balance, but the car will not explode or anything. Cons would be paying for an alignment twice.
Graham
1984 Carrera Targa
Old 07-15-2016, 07:37 AM
kdubb's Avatar
Thank you
for responding. It is probably better that I wait until I can do both front and back.
Old 07-15-2016, 08:26 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Originally Posted by gtc View Post
it will throw off the balance, but the car will not explode or anything. Cons would be paying for an alignment twice.
+1
'85 Carrera Targa
PCA/POC
Old 07-15-2016, 09:06 AM
Agree with this, but it also depends on how drastic a change you are going to make. A while ago, I had ordered some rear 28 mm plated and hollow torsion bars from ER to replace the stock 25s, completely oblivious to the fact that it would screw up my handling if I left the front stock at 18.8. Before processing my order, Chuck was decent enough to call me and explain that I shouldn't go above 26mm in the back without upgrading the front. I was very impressed by this level of customer service. I ended up deciding just to wait until such a time as I could do both. Anyway, Chuck is a great resource for the right combos to keep the car balanced.
Old 07-15-2016, 12:45 PM
Tidybuoy's Avatar
I would recommend waiting until you can do the rears or do the rears first.
I changed to 22mm front thinking I was doing a good thing. My very first drive, I spun the car on a on ramp that I previously had driven aggressively many times. It caught me off guard.
When I wrote about it on the forum, it was explained that the stiffness allowed me to go faster around the curve but when I got to a point that the car couldn't take the speed, I let off the gas and that caused instant extreme over steer. I'm not 100% sure I understand this but maybe someone with more expertise can chime in.
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 07-15-2016, 01:46 PM
toddu's Avatar
If you're trying to spread the cost out, just get them and sit on them for a while. Or, be patient for uses. Suspension is a slippery slope. You'll decide you want new bushings, then new brake lines, now the a-arms look like crap so powder coat those. Might as well yellow zinc plate everything while it's off. Etc. ;-)
Todd
'81 SC
Old 07-15-2016, 02:17 PM
kdubb's Avatar
Thank you all for your replies
I will definitely wait until I can get both Front and Rear done.
Thanks again.
Old 07-16-2016, 11:34 AM
Tags
suspension , torsion bar , upgrade
