Lousy gas mileage
I filled up the tank last week, since then have driven 100 miles (according to both odometers), and my gas guage is barely above 1/4 tank right now!!!!!!!!!!!!!!!!
If right now I have 3/8 of a tank left, this will put my gas mileage at 6.4mpg. (and no, I haven't left my car idling for hours on end).
Any ideas?
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 02-12-2003, 05:17 AM
dickster's Avatar
thats quite serious!
hole in the tank.
leaking fuel lines.
someones stealing it.
car needs a right good tune up/replacement bits.
i favour the last one
is your 02 sensor working?
clogged air filter.
knackered injectors.
binding brakes.
heavy right foot.
etc
etc
Rich
'86 coupe
"there you are"
Old 02-12-2003, 06:13 AM
Friend of Warren
bad fuel guage/sender?
Kurt V
Old 02-12-2003, 06:17 AM
dickster's Avatar
that was too obvious for me to think of.
they're not exactly accurate anyway. best thing to do is fill the tank, drive a couple of hundred miles then refill the tank - see how much you've used.
Rich
'86 coupe
"there you are"
Old 02-12-2003, 12:58 PM
slipping odometer, winter fuel + sub zero temps running the enrichment circuits. i get about that mpg. 100 miles per 12 gallons of the fun stuff. run a few more tanks when it warms up and see what you average.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 02-12-2003, 01:48 PM
Rick Lee's Avatar
My car recently sprung a leak just above the banjo fitting on the fuel line that goes to the fuel pump (which I replaced in August). It was spraying out from under the car and no one has been able to determine the cause of it. I thought we might just be able to cut the end off a new fuel line and graft or clamp it on the old one somehow without running the whole thing through the tunnel. WRONG. I just got a call from the shop that's doing it and they said the labor charge was gonna be a matter of days - not hours. I can't believe what a nightmare this seemingly tiny problem snowballed into.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-12-2003, 01:52 PM
Jbabic's Avatar
Runing a few lin is easy..>I did mine from the fuel pump all the way back...mine was leaking as well...Don't let me snow you...if you or someone you know is handy...you can do this...the saved labour will pay for the part itself.
Old 02-12-2003, 02:16 PM
Rick Lee's Avatar
Are you kidding me? The labor is gonna be a good 10x the cost of the line. What kind of car do you have? I doubt this shop would snow me and I doubt they'd waste even a fraction of the time doing what all they told me they had to do to R&R the fuel line, if it weren't necessary. Does someone else have a story like this on a Carrera fuel line? I'd like to gather some evidence.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-12-2003, 02:22 PM
Senior Member
Superman's Avatar
I think I heard something about a fuel line at the rear of the Carrera engine that gives problems and is inaccessible and expensive. But I do not know why it would take THAT much time to replace fuel lines. I would expect a complete set of fuel lines to cost more than the labor to install them. But then, I'm pretty FOS sometimes.
Mocha 1978 911SC. "Coco"
Old 02-12-2003, 02:52 PM
Are you sure the tank was filled? NYC has been so cold lately, maybe that has something to do with it??
Old 02-12-2003, 03:46 PM
nice doggie
Hetmann's Avatar
I had my fuel line replaced and I do not remember an excessive labor charge. Can't you just use the old line to pull the new one through?
Jerry
78 SC hotrod
02 Mini Cooper S
Old 02-12-2003, 04:04 PM
Rick Lee's Avatar
That was what we planned to do, but figured it was no biggie and the car was going to the shop anyway for an alignment. They said they had to pull my rack apart, shifter out, center console out and that it was a huge mess. He assured me it would have taken me a solid weekend if I knew what I was doing. Maybe Carreras are different.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-12-2003, 04:11 PM
Jbabic's Avatar
I actually used duct tape and pulled the new one through with the old one....but I have a 77 Targa....I don't really know of the big difference.
Old 02-12-2003, 04:19 PM
Bill Douglas's Avatar
Todd (NoStatic) had a similar problem with his car on the other coast and the general consensus was crummy petrol. Something like ethol (grain alcohol) alcohol added to the petrol by the fuel compaines to cheapen the product. Maybe do a NoStatic search.
Old 02-12-2003, 04:26 PM
We can count out the slipping odometer, both the one that you can set to zero (whatever it's called) as well as the actual one are in sync and show the same amount of miles based on this tank of gas. This is city driving but, not sitting in traffic that much...just cruising along in 2nd gear doing 25-35mph. Here's my little plan of action:
1) test another tank of gas
2) check the air filter (I guess just replace the d@mned thing)
3) appeal to you guys in helping me put together a list of things I should do to do a good tune up.
Thanks everyone,
Greg
Old 02-12-2003, 07:21 PM
nostatic's Avatar
yeah but Bill, I was getting a bit better than that. I think I was around 13-14mpg. If he's doing 100miles on 3/4 tank that works out to about 7mpg. Ouch!
Old 02-12-2003, 07:25 PM
pwd72s's Avatar
Try a different place to buy "gas", a different brand as well.
As far as the Carrera engine line they are full of crud, yes it's tough, but no more than a few hour job. (not talking about Rich L's thing, but the thing that Superman mentioned) You can do it in a few hours. Part of the problem is that the line is $500 from the dealer, but you can get another made cheaper than that, or in a pinch just use highpressure line and the metal from the stock line.
Of course, that's a totally different deal than this thread is actually about.
Old 02-12-2003, 07:46 PM
D idn't E arn I t
RANDY P's Avatar
How about the obvious? (back to Gspreeman)
How is the car running? Anything weird or new?
rjp
In the movies only bad guys sleep in king size beds.
Old 02-12-2003, 10:09 PM
Seems to be running fine. You would think if it were set too rich that the car would stall out when idling...but no problem there, idles along just fine.
Old 02-12-2003, 10:19 PM
