quick engine RandR question
its been over a year since I dropped my engine . In preparation for installation I repacked my CV joints and bagged them. Can I leave them tied up and out of the way while I reinstall and bolt up engine or do I have to finagle them into place while the engine is going in ? Its been so long since I took it out I don't remember .
Just getting the engine back in for a first timer seems daunting enough without messing around with greasy CVs at the same time. Thanks Guys oh as a point of interest I replaced them all when I got the car in 05 at 176K kilo , car is currently at 260K and although I see some wear on them and shiny in spots they are certainly doing fine and didn't even need a repack , boots were also in excellent shape if anyone is looking for a reference point. ( I have clamps at both ends.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) Last edited by theiceman; 07-22-2016 at 07:42 AM.. |
They should be fine as they are. Just make sure they are out of the way as you jack the engine into place (should be, just double check).
Todd
'81 SC |
Counterclockwise?
I found when I did it myself it was easier with them out, but not a big deal. Yours are easier than mine to remove as I have to get the axle nut off.
It's the throttle linkage that gets caught the most, but if you haven't put it on yet it's one less thing to worry about.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
RETIRED
Don't move the body around much w/o the axles stubs in the wheels.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Counterclockwise?
Why is that?
RETIRED
Wheel bearings get cranky w/o the stubs axles to hold it together....
disband
suspend them while bagged as you suggested. let them hang as low as you can before being supported by the CV. I used string or zip ties so the axle is easier to manipulate around the gear box where as wire is ridged and tuff to finagle at times. a few zip ties barely engaged & chain looped makes it easy to raise the axle support by synching one up after the motor is raised.
I like them hanging low so I can get the motor in place n up about half way, stop and get the axles free below the axle flanges and gearbox, then raise the motor into place while the axles hang below. the zip ties also when synched help you hold the thing in place to align to install the cv bolts.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft Last edited by juanbenae; 07-22-2016 at 05:23 PM.. |
RETIRED
Sorry, I assumed that the axles were completely out. Never mind....do as suggested ^^^
disband
that's a solo reinstall... a helper to work the axles as the motor raised is priceless....
also, a tight zip tie or even two thru a couple of the cv bolt holes aids keeping it as one with the boot & distorting while you fiddle with it. bummer is you have a bunch of grease zip ties to clean up n deal with when yir done..
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft Last edited by juanbenae; 07-22-2016 at 05:32 PM.. |
This is invaluable info. Thanks guys. I have tons of zips do gonna do the zip chain thing.
It will be a solo install. So will take my time. |
