-   -   Advanced A-arm Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/92227-advanced-arm-questions.html)
Superman 12-27-2002 12:15 PM
Okay, I fought with the castle nut at the bottom of the strut and the nut lost. Its shape is now that of a "C" instead of an "O".
Okay, the a-arm seems to be an assembly. The big part includes a long tube that houses the torsion bar. At the ends of these tubes there seems to be cylinder-shaped parts. Between these cylinder shaped parts and the long tube are bushings. I think these cylinder-shaped pieces slide off the a-arm so that the bushings can be replaced. This is correct, right?
I think my little offroad excursion did little more than mash the rear bushing, and put a gap along side the front bushing. So in theory, I would just need to readjust the positions of these cylinder-shaped end pieces. Right?
In reality, I should change bushings, and I'll do a search. Someone was so clever as to install a zerk fitting. Anybody remember who that smart guy was?
I think the a-arm is fine. The accident pushed the adjusting cap back through the cross member, and the cross member had to be welded, but it seems straight too. The adjusting bolt is bent pretty good too. So, I think the cross member and the bolt took the brunt of the force. I think the a-arm is fine, and I just need to change bushings and go.
surflvr911sc 12-27-2002 12:23 PM
You want Chuck's bushings. You are right on how to remove the bushings. You will need a vise and probably a torch. Chuck wrote a Tech Article on the job. I hope nothing important is bent there.
Argo 12-27-2002 12:39 PM
I believe he also has some bronze bushings which you may want to check out.
Argo
88 Targa
Superman 12-27-2002 12:55 PM
Okay, now I've done some more reading. Besides the bronze ElephantBushings, and aside from rumors that factory bushings are available, what are my other options? There is at least one hard plastic bushing out there, Weltmeister I believe. But some folks seem to be discussing a "street" bushing that is hard, and a "track" bushing that is even harder. Both plastic.
True? Two hardnesses of plastic bushings? Or just one kind of plastic bushing?
VincentVega 12-27-2002 01:12 PM
I would just buy a new arm, although 2 make sense to keep the suspension even. I am sure you've read about the process to fit the plastic bushings. Rather than take that gamble I opted for new arms, dont regret it at all. If you look around you can get them for ~$500/pair.
mm86911 12-27-2002 02:25 PM
I had a similar "off-road" excursion at an autoX last spring - four wheel drift coming out of a slalom and into a 6" curb. Wasted the wheel and bent the RH control arm pretty bad (luckily the spindle wasn't hurt). The frustration was magnified more so as I had just rebuilt the entire suspension 4 months prior with bars, rack spacers and "street" hardness bushings in the front. Bought a new control arm, used a propane torch to soften stock rubber bushings for removal and replaced with the poly ones. Also installed new ball joint just in case the prior one was compromised from the impact.
While I didn't add zerk fittings I hand fit them and used a Dremel to cut slots both inside and outside for grease reserve. Used a very thick clear moly grease recommended for these bushings. Several track events and a few thousand street miles and still no noise - even in the lower winter temps. I Highly recommended for the front control arms (used the neatrix for the rear).
Superman 12-27-2002 04:34 PM
I still think my a-arm is not bent, and I'm considering having it put on a gig to test. After talking to a trusted local auto guy, I have a question about these poly bushings. He says he sees a LOT of broken/beat up ones. A LOT.
Anybody seen any broken or mangled plastic bushings?
tobluforu 12-27-2002 05:18 PM
Someone on this board a while back posted pics of his poly bushings. He cut grooves in them and added zerk fittings. Do a search on this. It looked like it worked great!
Joeaksa 12-27-2002 05:20 PM
I have two extra "A" arms from a 81 SC. Not really wanting to sell one but if you want to use one as a pattern to make sure yours is or is not bent, would be glad to loan it to you.
Joe
BGCarrera32 12-27-2002 05:33 PM
Yo Superman-
I'm doing the exact same stuff right now. Once the A-arm was out I clamped it lightly to the workbench and heated each rubber bushing indirectly with a propane torch to weasel the cylindrical pieces off. While you have it hot (and have gloves on) take a rag to the a-arm where the bushing was as this is a good time to wipe off any rubber gunk that was left.
You could compare your a-arms left to right on the workbench by taking some precise measurements at certain points off the table. Obviously, if the two arms are not symmetrical, one of them is bent. And then you're on to a more careful inspection. Also check to make sure your front brackets with the tow loops are symmetrical as well. I found one of mine was tweaked pretty nice after the PO ran up a steep drive or something. Obiviously you could see the hook thing was bent, but not until it was removed did I see that the thick gauge metal section was twist outta whack as well. And then I saw the sheet metal on the car where the bracket mounts was shoved up a tad...
I bought the 4 poly bushings kit from Pelican. I would love to buy Chuck's bronze bushings but at $60 for the poly ones and $190 for Chuck's, poly won out... I have a tough time believing if you greased the poly ones liberally at install that they would break apart...sounds like a story to me but then again this is my first bushing install...
-BG
Tyson Schmidt 12-27-2002 06:30 PM
Jim, don't use the plastic. Use the street hardness Polygraphite bushings. They are roughly right in the middle between rubber and plastic as far as hardness. Had them on my car and they felt fine. No squeaks or noise/harshness.
Personally, I hate plastic bushings. They definitely do break apart fairly quickly. The grease gets squished out in short order, and they just don't stay together after all the impact and friction. Every set I've seen in the rear of a 911 has been disintegrated or at least starting to tear. The front ones do fair better, but they are especially noisy and harsh.
rs911t 12-27-2002 06:59 PM
I just finished R&R of my front suspension. The Weltmeister bushings were just fine so were cleaned, lubed and reinstalled just like everything else. The front is noticably tighter and with much better feel. They've been on the car for years.
They can be hard to pull off. I needed a vise on the a-arm and a cheater bar to get'em pulled.
Superman 12-27-2002 07:58 PM
Tyson! Wish you were here, obviously. But I think I'm getting this figured out. Thanks for the offer, Joe, but I really am pretty sure the a-arm is not bent. Considering the jig test, but I think it is straight.
So, Tyson, it sounds like there are plastic, non-'poly' bushings. Mark kept saying the broken ones are a particular color. Red, I think. He thinks they're poly, but perhaps they're the plastic ones. I have not heard of this trouble with the poly bushings in our cars. And besides, I think this (a-arm application) is the right one one for firmer bushings. Bear in mind, I am one who respects the designers of the factory setup.
Thanks, all.
surflvr911sc 12-27-2002 08:06 PM
The street-hardnees poly bushings are Red. That's what I installed b/c Chuck's bushings were not avilable yet. I like them but I will be installing bronze bushing as soon as I have a reason. You are going to do both sides, right?
Tyson Schmidt 12-27-2002 09:09 PM
The poly bushings I've used are Black. Never seen red. The plastic are also black. I'm referring to the Weltmeister bushings.
I don't know who makes the red bushings.
surflvr911sc 12-27-2002 10:17 PM
Tyson, you are right. I just went out and looked at mine and they are black. The red must have come from a picture? I found Chucks Poly bushing article, here.
Superman 12-27-2002 11:06 PM
I'm just out of questions, guys. Street poly bushings. New adjusting screw. Zerk fittings. I wonder if the bushing could be 'staked' by a short screw through the bracket and into the bushing. Being careful not to deform that inside bushing bore.
surflvr911sc 12-27-2002 11:24 PM
huh?
RoninLB 12-27-2002 11:28 PM
I think Super would love the Welt street bushings in his part of the world.. great bang for the buck.. I used some gorilla snot bushing grease.. front and rear still in great shape after 40k miles... like you can twist the steering wheel in a lane quickly back and forth at 70mph and not have to wait for the front end to catch up with your input...........Ron
Superman 12-27-2002 11:42 PM
Ron, you're a night owl. Doc, the zerk fitting addition, the brainchild of Chuck Morehead, may poke slightly into the bushing but it is wondered whether the bushing could rotate. Probably not if I fit them properly, but I'm wondering about staking them still with a screw.
Tyson Schmidt 12-28-2002 08:40 AM
So are you drilling a hole through the bushing to get the grease through to the inner surface of the bushing? Is that why you don't want it to rotate and block off the feed hole?
Chuck Moreland 12-28-2002 08:47 AM
The OD of the bushing should be snug in the housing, with no lubrication at all. Staking shouldn't be necessary.
surflvr911sc 12-28-2002 08:50 AM
Read his article again. I think that they will be fine the way Chuck explains. The A arm rotates inside the bushing while the mount and bushing remain still by the zirk fitting holding them together. The way Chuck says to turn the bushing on the lathe is also conducive to this.
EDIT: The man himself beat me to it!
tobluforu 12-28-2002 08:51 AM
maybe this.... http://forums.pelicanparts.com/porsche-911-technical-forum/6918-warning-before-upgrading-torsion-bars-change-bushings-pics.html?highlight=zerk
pbs911 12-28-2002 09:14 AM
Tobluforu said everything I could. In fact he pointed right to my thread. I also used the Weltmeister black poly bushing and have been pleased since. I only wish I would have cut a grove along the ID of the bushing to distribute the grease. But even with the way I set up mine there is very, very little suspension noise. I found no need to alter the bushings in any other manner except for the zirk fitting during my project.
Superman 12-28-2002 10:13 AM
Yes, everyone is making perfect sense. You're all ready for the final exam. Island, will you give us our finals?
Tyson, precisely. Chuck, I think you're right. I don't have a lathe, but I have a Dremel and more patience than I did when I was 23. If it is custom shaped, and especially if the sheet metal is not round, the bushing should stay put. I also know to ensure the inner bore is not pinching the a-arm. I'll be cutting some clever grooves there for fresh grease. Should work great.
phaques 01-09-2003 06:20 AM
Any tricks to getting the new poly carb bushings installed on the A-arms?
cstreit 01-09-2003 06:51 AM
Ist there a tech article somewhere on replacing the bushings? Mine need to be done in front. Will this necessitate resetting the ride height?
kstylianos 01-09-2003 08:27 AM
Superman,
"I don't have a lathe, but I have a Dremel and more patience than I did when I was 23"
I just went through this exact same process with the street hardness (black) Welt. bushings. They are hard, but have a consistancy and feel of hard rubber, pretty pliable. I've BTDT with the Dremel and would NOT suggest using a dremel for ID enlargement, you will not get a consistant ID all the way through. I used the Dremel method and the fittment was not very good at all...snug in some places, tighter in others, and if you take off a wee bit too much, you get a sloppy fit. BTW: I used the flapper 80 grit sanding wheel attachment. After dremeling all 4 bushing, they did not feel right on the a-arms so I ordered another set and used another method for hand fittment.
The OD of the welt. bushings should fit snugly into the housings, so you should not have to take any material off the OD. I used a wooden dowell, larger than a broom stick but smaller than ID of the bushing. I bult up the OD of the dowell with duct tape and wrapped/affixed 80 grit Al oxide paper around the end of the dowell, making a snug (not tight) in the ID of the bushing. With the housing on the bushing, rotate, rotate, rotate the bushing on the end of the dowell back and forth, getting a good consistant shaving of the ID. I used a screwdriver in the holes in the housing for leverage. The housing may slip around bushing, so try and get the slimy goop (they may be prelubriacred from factory) off the OD of the bushing before you slip it into the housing. When the ID openes up a bit, place a sliver of ducktape under the sand paper to increase the OD of the dowell and contiune the process. Remember to constantly try to hand fit the bushing w/ housing on the end of the a-arm. A good fit will slide on, rotate freely with little resistance, but with NO horizontal/vertical play on the a-arm. I was able to hold the a-arms by the bushings with housing attached it would rotate pretty freely.
This was the most tedious process of my front end overhaul, taking about 45 minutes per bushing to get a good fit, but beats the $450 charged by other companys to do this for you. I was very happy with the fitment using the above process, and I am quite an anal fellow.
I also fitted 6mm zirk grease fittings and created a figure-8 grease groove inside the bushing.
Chuck gives a good explanation for fitting grease fittings here
I also ordered the special poly bushing lube from or host. Nasty stuff, sticks to everything.
PEL-SUSGRS8 - Suspension Bushing Grease, 8 oz
-Charlie
arcsine 01-09-2003 09:50 AM
And what do we cut the grooves inside the bearing with. The ubiquitous Dremel tool would seem to work but ....
kstylianos 01-09-2003 09:56 AM
To cut the groove in the bushing, I used the dremel with a high speed cutting attachment similar to #190.
Dremel
