Should a muffler from a 77 fit an 89 3.2?
I am looking at a 77S muffler, to take temporary residence where my M&K currently sits. 89 3.4, SSIs into the M&K.
My thinking is that they're universal from 74-89, as M&K says. But I can't pull my muffler to check distance and I'd hate to buy and ship a muffler only to find out otherwise.
http://www.mkexhaust.com/products/911_2i1o.html
Any thoughts would be appreciated.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 08-02-2016, 03:48 PM
weren't 77 911s 1 in? Believe the 2 in ssi was based on the 1974 and earlier headers (which feed to the muffler via two inlets. So, unless the 77s was converted to SSIs (or '74 or earlier factory headers), I don't believe it will work
Old 08-02-2016, 03:58 PM
This is definitely a 2-in, 1-out.
89 Carrera 3.4
Old 08-02-2016, 04:17 PM
safe's Avatar
The it will fit if you modify it slightly. The 3.2 engine mount is bigger than on the 2.7 so you will have to make the center indentation in the muffler bigger.
You can do that with a big hammer, done it two times myself.
Magnus
Old 08-03-2016, 12:38 AM
That, and the 77's muffler hanger straps won't work. You can modify the 89 hanger strap instead.
Old 08-03-2016, 01:28 AM
safe's Avatar
It doesn't?
I think mine did.
Edit: I think I used the 77 muffler bracket as well.
Magnus
Old 08-03-2016, 01:43 AM
Brew Master
cabmandone's Avatar
As I understand it, the only real difference was the exit angle of the tailpipe. My brother bought a muffler for an older car (2 in 1 out) and I don't recall the year but he had to cut the tailpipe and have it re-welded in the proper angle. That should be worst case scenario for you.
Old 08-03-2016, 05:45 AM
safe's Avatar
Thats true, the tailpipe from a longhood muffler wont tuck under the impact bumper.
Magnus
Old 08-03-2016, 05:49 AM
