Securing rear shelf
Could someone explain or take a photo of how the upholstered rear shelf is attached to the underlying support. Pretty sure mine is not OEM. There are 4 screws on the vertical section which are the only fasteners. Nothing on the top section where the speakers attach. During a hard brake during my last "spirited" drive the whole the thing slide forward and is now not secured.
Trying to understand how it should be. Thanks Chris |
which attaches to the body of the car. You first attach the clip, then the screws. Here are a few pics on the next post. Gerry |
Pics
There are no fasteners on the top portion.
JR |
Shelf
^^^^^ Gerry |
Jr |
I am just switching out rear speakers. In picture above it looks like parcel shelf piece is separated from the vertical piece - I think these two pieces are / should be glued together - see below picture. Also, between the speakers is an ~ 2" x 2" x 14" piece of dense foam. When installed using clip, 4 vertical screws, the foam helps to keep the shelf secure, wedged in below rear glass seal and prevents any rattling.
http://forums.pelicanparts.com/uploa...1469805382.jpg |
| All times are GMT -8. The time now is 08:27 AM. |
