Wheel Stud Replacement
All,
I need to replace my wheel studs in the rear. Does anyone know where I can obtain them? I have checked pelican with no luck. Also, is this pretty easy to do? Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
Friend of Warren
Checked pelican? You're kidding right?
Wheel Stud S-331-671-01 $7.07 Wheel Stud, 50mm, 10 Pack F-341-671-02PK $99.00 911/912 Wheel Stud, 52mm A-331-671-00 $5.50 911/912 Wheel Stud, 52mm, 10 Pack A-331-671-00PK $49.40 911/912, 928 Wheel Stud, 72mm A-331-671-01 $5.50 Wheel Stud, 45mm, each S-341-671-01 $5.50 911/912/944 Wheel Stud, 67mm C-331-671-00 $5.50 911/912/944 Wheel Stud, 67mm, 10 Pack C-331-671-PK $49.40 Wheel Stud, 100mm, 10 Pack H-331-100MMPK $109.80 Wheel Stud, 100mm H-331-100MM $13.20 911/912,944/928 Wheel Stud, 72mm, 10 Pack A-331-671-01PK $49.40 Wheel Stud 50MM, 928, each F-341-671-02 $9.90 Wheel Stud, 72mm, 10 Pack A-331-671-PK $49.40
Kurt V No more Porsches, but a revolving number of motorcycles. |
HUH,
Where are they? I looked everywhere. Are they easy to replace? Thanks a bunch. Cheers, James
