-   -   83 SC @ frame bench need specifications (http://forums.pelicanparts.com/porsche-911-technical-forum/923658-83-sc-frame-bench-need-specifications.html)
Blackbyrd 07-30-2016 11:16 PM
Looking for specifications of the chassis for an 83 SC
I have some for an SC PRE 81 and 84+ CARRERA. But want to make sure I have the correct dimensions and compare them.
Any one have copies of the pages from the books
Something I can print for the shop
Not looking for the 70s or late 80s need exact 81-83 SC specific dimensions/measurements
Coupe !
Mark Salvetti 07-31-2016 09:30 AM
Are you sure they are different? My factory manual seems to be current through 1983 (it includes pages for the 1983SC, but I bought it used around 1990, so it might be missing some supplements).
Anyway, there are only two pages with frame dimensions. This first one says it is good for 1972-on:
https://photos.smugmug.com/Cars/Pors...16_0000-XL.jpg
And then there is this one with the companion dimensions page. The two drawings only have a few common measurement points, but where I checked the overall dimensions were the same, only the allowable tolerances in the second set are slightly greater (by 0.5mm or so):
https://photos.smugmug.com/Cars/Pors...16_0001-X2.jpg
https://photos.smugmug.com/Cars/Pors...16_0002-X2.jpg
You can download full resolution images (including a couple of the first page that can be taped together to show the entire image) here: Workshop Manual Scans
Mark
walt 07-31-2016 10:19 AM
I have a technical specification book for model years 82 and 83. Verified numbers in the table above are the same.
Walt
