-   -   Using Timing Light on Twin Plug Engine? (http://forums.pelicanparts.com/porsche-911-technical-forum/924186-using-timing-light-twin-plug-engine.html)
73ess 08-04-2016 09:10 AM
I need to check the timing on a twin plug 3.0 engine. Do I just connect it to number 1 spark plug cable as I would for a stock single plug engine? Can I use my timing advance knob on the timing light or will the readings be off for a twin plug engine?
Steve@Rennsport 08-04-2016 10:28 AM
Use #1 plug just like on a single-ignition engine.
Time the car just like you would with your dial-back timing light, but bear in mind the differences in timing values. :) :)
73ess 08-04-2016 10:30 AM
Thanks Steve. What do you mean by "differences in timing values"?
T77911S 08-04-2016 11:37 AM
less advance is needed with dual plug
rsscotty 08-04-2016 11:39 AM
I think what Steve is referring to is that you don't use the single plug timing numbers on a twin plug engine.
boyt911sc 08-04-2016 12:05 PM
Could you elaborate.........
Steve,
Could you elaborate more on this subject? Thanks.
Tony
911SauCy 08-04-2016 01:46 PM
IIRC, A single plug 3.0 engine idles 5deg before TDC and advances to 25 deg at 6000rpm.
Because a twin plug is more efficient at burning the fuel charge there will be less timing advance required to get the power out of it.
I just don't personally know what the numbers are.
Someone chime in with those deets!?
73ess 08-04-2016 08:45 PM
Yes. Would be great to know the timing numbers for a twin plug 3.0.
